What thread are water heater elements?
   / What thread are water heater elements? #1
LD1
Epic Contributor
Central Ohio
Kubota MX5100
Wondering if anyone knows off the top of their heads what thread heater elements are.
Looking to get a thermometer to put in place of the upper element in my buffer tank for my 2-tank geothermal DHW heating setup.
Going to Menards this afternoon to get the pex and fittings to plumb it and wanted to see what they have
   / What thread are water heater elements? #2
I believe NPT is standard
what size is what I was really looking for
   / What thread are water heater elements? #4
1" NPT I think. See if they have a replacement element there to check.
   / What thread are water heater elements? #5
I bet menards sells elements. Match it up.
   / What thread are water heater elements? #6
water heater elements are standard 1" IPS threads.
   / What thread are water heater elements? #7
I did a little search and it looks like 1"npt is pretty standard for most home water heaters. Did see one that was 1-1/4"npt, but it was a larger 6500 watt.
   / What thread are water heater elements? #8
Be a bit careful. I believe that the thread in the tank is a straight thread since O-rings or gaskets are used to seal the element. So an NPT tapered pipe or fitting may not easily seal, or seal poorly (leak). For your need I would start with an old element, remove the element and electrical connections with a saw and grinder, weld or braze the holes shut then drill and tap a 1/8" or 1/4" NPT to fit your thermometer. You could also remove the P/T valve on top, which is a 3/4" or 1" NPT and use an adapter to fit the thermometer.
Paul
   / What thread are water heater elements? #9
Check your tank for an optional T&P plugged pipe fitting on the top of the tank, like mine has.
Tank has the T&P valve. Want to leave it there. Are you saying yours has a second T&P port?
2003 STERLING ACTERRA 11FT FLAT BED (A51222)
2003 STERLING...
2013 Ford F-150 4x4 Ext. Cab Pickup Truck (A48081)
2013 Ford F-150...
2002 International 9200i Truck (A52128)
2002 International...
2014 International Durastar 4300 Terex BT2047 47ft Crane Truck (A50323)
2014 International...
2015 VOLVO VNL SINGLE AXLE DAY CAB (A51222)
2015 VOLVO VNL...
2015 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A50323)
2015 Chevrolet...
