pto shaft cover retention chain loop repair ??
   / pto shaft cover retention chain loop repair ?? #2
that's what I've been doing ;-0 but i had the grease gun out to service the many drive elements I've "collected", and that loose chain just started to bug me ;-)
   / pto shaft cover retention chain loop repair ?? #4
If you forget to check that it spins regularly, one day it won't spin and someone can get hurt.
I would that a heavy duty nylon zip tie and secure a small steel ring to the cover, then attach the chain to that.
Don't worry Garry, the outer sleeve has the chain intact , and that covers all the exposed shaft but the tractor end bell.
The tye wrap sounds like a good idea!, if it starts to run loose, I'll just grease it!
   / pto shaft cover retention chain loop repair ?? #6
You could epoxy an attachment point on the cover. Zip tie would be easy. Doing nothing, easier still.
I've never found an epoxy that sticks to outdoor flexible plastic. The do nothing fix has held for a couple of years now. ;-)
   / pto shaft cover retention chain loop repair ?? #8
A large hose clamp works great.
2015 FORD-750 XL SUPER DUTY DUMP TRUCK (A51406)
2015 FORD-750 XL...
2015 CATERPILLAR 262D SKID STEER (A51246)
2015 CATERPILLAR...
2016 Big Tex 24ft. T/A Flatbed Trailer (A50322)
2016 Big Tex 24ft...
NEW Wolverine Skid Steer Bucket Forks (A53002)
NEW Wolverine Skid...
2013 FREIGHTLINER BUSINESS CLASS M2 VACUUM TRUCK (A51406)
2013 FREIGHTLINER...
