Anyone debate buying vs renting a pressure washer?
   / Anyone debate buying vs renting a pressure washer? #51
Overall that's a very nice unit ,a little bit low on the GPM's for pro use, but for farm/home use more than enough.. The motor is great and any CAT pump is arguably one of the best made. Should last you a very long time with proper care!
   / Anyone debate buying vs renting a pressure washer? #52
I actually scored a genuine Steam Jenny (from the 70's) a month or so ago for $125. Very simple. Kerosene or Diesel fired (Kerosene is cleaner). We had these in the military and they are awesome. It's a combo unit so it does two different PSI, pressure, and GPM settings. You get lower temperature (200 degrees or so) with higher PSI & GPM or higher temperature (over 312 degrees) with less pressure & GPM. Perfect for engines, tractor, undercarriage etc. as it won't push water in places it doesn't belong (or peel paint) like 4,000 PSI would :D
   / Anyone debate buying vs renting a pressure washer? #53
Wow! those are wonderful machines and a great piece of history!
Here's one that's $1,000 and gets great reviews. It's a Simpson 4200 psi with a Honda GX engine and gets great reviews. It has a "Triplex Plunger" pump rather than the Cat pump I think I would prefer (based on this thread) so I don't know what to think. Can someone that knows pumps and washers take a look at this please? I've evolved from renting to buying and need a little help.
   / Anyone debate buying vs renting a pressure washer? #55
Sorry but I think we are missing the link Sixdogs
Oops. Forgot the link.
Here's one I'm thinking of. $1,000.
Simpson PS4240S PowerShot Professional 4200 PSI Gas-Cold Water Pressure Washer w/ Honda Engine
Here's another with a lesser engine but a CAT pump. $719.
Pressure-Pro PPS2533HCI Professional 3300 PSI Gas Cold-Water Aluminum Frame Pressure Washer w/ Honda Engine & CAT Pump
Here's the third one at $800.
SIMPSON PowerShot 4, PSI Commercial Gas Pressure Washer - Powered by Honda - Sam's Club
One final one and with a CAT pump.
Pressure-Pro PPS3030HCI Semi-Pro 3000 PSI Gas Cold - Water Aluminum Frame Pressure Washer w/ Honda Engine & CAT Pump
I hate to spend $1,000 and would prefer the $720 to $800 category. Some of the comments of the $720 one make me queezy about that one. The $1,000 one has 50 ft of hose, and great reviews. Plus I keep looking at farm auctions.
   / Anyone debate buying vs renting a pressure washer? #57
The big thing is the GPM - the more GPM the more "cleaning power". A lot really depends on what you want to clean, the time you want to spend and the money you want to spend. More GPM = faster cleaning. If you are using surface cleaners the higher pressure and more GPMs are needed (multi heads need a LOT of flow). You will notice that with the good pumps as GOM goes up so does the price. Not a real big difference is clean "power" between 3200 and 4000 psi, much larger jump with 3 gpm to 4 gpm.
More pressure is great for concrete, rock, etc.... I personally cut my 4000 PSI unit back a fair amount for the truck and tractors, want to not strip the decals and possibly the paint (by the way don't use the "red" tip for your car/truck/tractor - it can destroy paint at 4000 psi VERY VERY quickly.) A good pressure washer will really surprise you - they are a different animal.
   / Anyone debate buying vs renting a pressure washer? #58
If your shopping, water quality is foremost to consider, If you have hard water, it will ruin a pump that has Non ceramic pistons..I talked to a guy at the Karcher service center that works on the side.. The first thing that they check for on a warranty job,is hard water signs,, and that ceases any warranty on the spot,,
Great advice. I have a soft water outlet in the garage so I could use that.
1013 (A51573)
1013 (A51573)
ALL TITLED ITEMS HAVE A $35 TITLE FEE!!! (A50774)
ALL TITLED ITEMS...
2012 Chevrolet Cruze Sedan (A50324)
2012 Chevrolet...
2022 CHEVROLET 2500HD CREW CAB TRUCK (A51406)
2022 CHEVROLET...
2006 V.E. ENTERPRISES 130 BBL STEEL VACUUM TRAILER (A52472)
2006 V.E...
