3-Point Hitch To replace, or not replace the 3-point lift arm seals on Jinma 284
   / To replace, or not replace the 3-point lift arm seals on Jinma 284 #1
leop
Member
Los Gatos CA
Jinma 284, Cat D4 Dozer
Hi Everyone,
I have a Jinma 284 tractor. I have the transmission top cover and Hydraulic top cover (under the seat) off and drained in order to rebuild the piston seals on the 3-point. The kit includes seals for the lift arms. Now my current arms are not leaking or drifting out of the correct position so I am inclined to not go to the trouble of replacing the seals.
However, taking this all apart and replacing the fluids is a real pain and so I don't want to skip doing the 3-point arm seals only to find out later that I should have becuase of the BLahh ... Blahhh ....Blahh problem.
So my question to those more experienced than I is: Is there any reason to mess with the seals on the 3-point arms if they are not leaking?
Thanks for any insight you guys and gals can provide.
Leo
   / To replace, or not replace the 3-point lift arm seals on Jinma 284 #2
2005 Sterling Acterra Tender Truck (A53473)
2005 Sterling...
2025 SDLANCH SDLGC80 UNUSED Electric Golf Cart (A53117)
2025 SDLANCH...
2020 Featherlite Aluminum Stock Trailer (A52384)
2020 Featherlite...
Chevrolet C8500 Flat Bed with a Moffet Kit (A53473)
Chevrolet C8500...
1999 Ford LA-9000 Aeromax Godwin Steel Dump Truck (A52384)
1999 Ford LA-9000...
2025 CFG Industrial QK16R (A50123)
2025 CFG...
