Ford 860, PTO Flail Mower disengages pto under load
   / Ford 860, PTO Flail Mower disengages pto under load
One of these days I swear I'll run into something easy that turns out easy. The replacement shaft arrived, but it won't fully insert. It'll go until the cover is maybe 3/8" from seated, and then just stick. I can turn the shaft by hand, and hear gears turning. Shaft doesn't look to be keyed, but I tried rotating it a bit at a time, and still can't get it further in. Any tips and/or steps I'm missing?
   / Ford 860, PTO Flail Mower disengages pto under load #12
Bring me up to date, what shaft did you order, from where, have you measured the old one and the new one tip to tip?
   / Ford 860, PTO Flail Mower disengages pto under load #14
if it's the exact same length shaft, give it a few taps with a copper or brass mallet.
Mallet got it 95% of the way there. Bolts tightened it up. Can't imagine I'll ever be able to pull it out by hand. Hopefully that won't end up being my problem =p
Hopefully I'll get some time to hook it up to the flail and try it out over the weekend. Thank you for all of the help.
   / Ford 860, PTO Flail Mower disengages pto under load #16
Make sure the engagement lever still works. I have seen son with burs on shaft splines that had to be tapped in, but then couldn't be engaged till slid out and filed.
To remove, put a bolt in hole and drive out with hammer, or use a slide hammer to tug it out.
You can clean the splines then smoke with acetylene, reinsert, pull again, and see witness marks where it binds.
Hopefully it just works :)
As far as I can tell, it's working great. No engages properly, no vibration on the engage lever. Didn't pop out once. Now to get the flail into better working order. Thanks again for the help Soundguy.
   / Ford 860, PTO Flail Mower disengages pto under load #18
good deal.
John Deere (A50322)
John Deere (A50322)
2019 FORD F-650 SUPER DUTY BOX TRUCK (A51406)
2019 FORD F-650...
2015 Kia Cadenza Sedan (A53424)
2015 Kia Cadenza...
Tailgate For Pickup Truck (A53117)
Tailgate For...
2018 LAMAR TRAILER 40' T/A GOOSENECK TRAILER (A53843)
2018 LAMAR TRAILER...
2013 Ford Taurus AWD Sedan (A51694)
2013 Ford Taurus...
