Battery for electric fence...how long before discharge?
   / Battery for electric fence...how long before discharge? #1
WoodChuckDad
Elite Member
Free Union, VA
Kioti RX7320 Power Shuttle Cab, Komatsu PC130-6
I ordered a Cyclops fence charger from Valley Farm supply. I ordered the whole solar charger and field box kit. Unfortunately, they sent the fence charger but the solar panel charger and box won't be ready for a few weeks. It appears they have those built by local Amish community when ordered. So I'm wondering, if I hook up the fence with a battery, will it be dead after a day or two? Or will it last a week or more?
   / Battery for electric fence...how long before discharge? #2
When I used an electric fence - approx 1/2 mile - a standard car battery would last 3+ months.
   / Battery for electric fence...how long before discharge? #3
I would guess 2-3 days, but if you look at the watts or amps drawn by the fence charger and the amp hour rating for the battery, you should be able to tell.
IE: If the charger pulls 0.5A and it is a 50 amp hour battery, it will run about 100 hours on a charge.
Aaron Z
I was planning to use a deep cycle battery or large car battery. I've read that deep cycle is better for this application.
   / Battery for electric fence...how long before discharge? #5
I agree a deep cycle would be best.
   / Battery for electric fence...how long before discharge? #6
Remember - each time the fencer charges the fence its only on for a micro-second. So, for the fencer to completely discharge a car battery with 50 amp hour capacity will take months. The fencer drawing 0.5 amps is not a continuous draw.
Easy way to check - set the system up with a standard car battery - go out after a week, take off your shoes and grab the fencer wire. Don't be surprised when it knocks you on your butt.
Remember - each time the fencer charges the fence its only on for a micro-second. So, for the fencer to completely discharge a car battery with 50 amp hour capacity will take months. The fencer drawing 0.5 amps is not a continuous draw. Easy way to check - set the system up with a standard car battery - go out after a week, take off your shoes and grab the fencer wire. Don't be surprised when it knocks you on your butt.
I don't think I want to do that. This is a 5 joule charger.
   / Battery for electric fence...how long before discharge? #8
Thanks for the input. I had not seen that on their site, but I did email Alex at Taylor fence, the manufacturer and he said the same thing. Recommended a deep cycle battery and said 100 amp hour battery will last 14 days.
   / Battery for electric fence...how long before discharge? #10
If you use a solar charger, you should be able to save your $ and use a regular (vs deep-cycle) battery. Today's typical amorphous solar panels and charge controller will keep at least a trickle going whenever there is light - it doesn't need to be direct sunlight. So a deep-cycle is really not needed.
My solar gate operator supplier actually recommends using a regular auto battery - get the group size that fits your vehicle so that you can interchange if desired. And buy at wherever has the longest FULL REPLACEMENT warranty. That was Sams when I bought. If your battery shows any deterioration when it's close to the warranty expiration, bring it in for a full, free replacement.
Hose Reel (A53424)
Hose Reel (A53424)
2016 Club Car Carryall 1500 4x4 Utility Cart (A55758)
2016 Club Car...
UNUSED LANDHONOR 82" FORK EXTENSIONS (A54757)
UNUSED LANDHONOR...
2014 VOLVO EC220 DL EXCAVATOR (A51406)
2014 VOLVO EC220...
Galvanized Livestock Gates - (2x Gates) (A55218)
Galvanized...
2008 Ford F-550 11ft Utility Flatbed Truck (A52377)
2008 Ford F-550...
