Getting rid of old gas.
   / Getting rid of old gas. #1
RSKY
Kentucky, West of the Lakes, South of Possum Trot.
Kioti CK20S
Helped a friend clean up her dad's house after he died. I ended up with several gas cans that she couldn't use. The gas is at least 18 months old. So I am using about a quart to half gallon every time I fill up the Bad Boy.
Does anybody see any problems, have another solution?
   / Getting rid of old gas. #2
find someone you don't care for and put some EXTRA gas in their tank for them. they will think their car is getting extremely good gas milage.
   / Getting rid of old gas. #3
just kidding
   / Getting rid of old gas. #4
I got about 10 gallons of really old gas (10 years) from work, I will use to start brush fires. Will likely mix with diesel and used motor oil to lower volatility. Though I did use about a quart on a fire about a month ago, straight, didn't 'flash' like fresh gas at all.
   / Getting rid of old gas. #5
Old gas not treated turns to something close to varnish. Guess if you run enough fuel through anything a small dose shouldn't hurt anything. Too much and I'd be worried about fuel injectors etc. Personally I only buy the premium fuel (no ethanol) and add Stabil. In the old days I saved the sawdust from my workshop to use as a sponge on the fire pit. Dump the gas before you light the match of course.
   / Getting rid of old gas. #6
That should work. It will get diluted good that way.
Don't dump it on the ground and lite it up. I had some gas in a boat I wanted to get rid of so I dumped a couple gallons on the driveway but I didn't have matches with me. I walked 50 feet to get some and by the time I lit it up the fumes traveled about 50 feet into a woods. Luckily for me it just flashed but wasn't a sustained heat so the woods and the house was spared. Fumes will travel.
   / Getting rid of old gas. #7
I doubt a quart to half gallon is big deal.
I use mine for burning stuff. Dump it in a non approved container.
   / Getting rid of old gas. #8
In a previous house we had the dreaded box elder bugs that would winter in the garage. Cleaning up one day and got a big pile of them. Never having found anything that would kill them I looked around and found a can of Coleman stove gas. Figured if they could keep it on the shelves at WalMart it would do the trick. When I struck the match I saw what looked like that ending scene from "Raiders of the Lost Ark". Fast upward spiral of hot blue flame. We have moved a few times since then and seem to have traded box elder bugs for Asian lady beetles. Not so sure which ones I hate the most but I won't repeat the experiment.
Nobody has posted anything screaming that I'm going to screw up my engine so I guess I'm OK doing this. My plan is to use a quart a tankful until it is gone. May put a gallon or two in my truck to speed the process.
A recycling place near us uses a Kubota skid steer. The owner had a diesel pickup that had serious engine trouble due to bad diesel. Like a new engine if I remember correctly. So they drained the tank and burned the fuel in the Kubota. Said the filters it had enabled them to burn anything.
Just telling.
RSKY
   / Getting rid of old gas. #10
That what I do with any old mixed gas I have. I mix it at 1/2 gallon to 5 gallons in my boat. Never misses a beat.
2015 JEEP PATRIOT (A51406)
2015 JEEP PATRIOT...
KUBOTA SVL97-2 SKID STEER (A52705)
KUBOTA SVL97-2...
2013 PETERBILT 386 TANDEM AXLE SLEEPER TRUCK (A54607)
2013 PETERBILT 386...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
2014 Ford Fusion SE Sedan (A53424)
2014 Ford Fusion...
