1538 with 1538 B backhoe revisited
   / 1538 with 1538 B backhoe revisited #1
Deflexor
Northern Idaho
Mahindra 1538 HST
Referring to this thread http://www.tractorbynet.com/forums/mahindra-owning-operating/357220-1538-backhoe.html
Upon further reading and pondering....
I am thinking the backhoe has "open centers" on the valves, is this the return line (third line)?
I am sure that I am dead heading my pump (which dickfoster mentioned in the earlier thread) because the return line isn't hooked up and I can hear the pump straining. I have learned from reading that dead heading the pump causes usage of the relief valve and will generate a lot of heat, and yes, when I use the backhoe the hydraulic cylinders get hot enough to burn me.
I now know that the BH is normally run on a power beyond from the FEL. My BH is plumbed on a remote (and I am not sure why it was done this way). Rather than putting the power beyond plumbing on the FEL can I still hook up the third line to dump into the tank somehow to prevent pump dead heading and stay on the remote? Will this solve the issue?
Thanks to all of you for sharing your knowledge.
   / 1538 with 1538 B backhoe revisited #2
No' wait till the spool seals fail or the BH valve body cracks and leaks. Then your can put the screws to those clowns that installed it that way :duh: Your flirting with disaster if not soon definitely later. :mur:
   / 1538 with 1538 B backhoe revisited #3
Can you send me some pics of how it's plumbed? IIRC you called me on my cell? You can text them to me...
   / 1538 with 1538 B backhoe revisited #4
Assembly instructions are in the operators manual. :thumbsup:
2016 Ford Transit 350 Cargo Van (A50323)
2016 Ford Transit...
New/Unused 7ft 20 Drawer Stainless Steel Workbench (A51573)
New/Unused 7ft 20...
2002 International 9200i Truck (A52748)
2002 International...
2001 Club Car Carryall Utility Cart (A51691)
2001 Club Car...
Tandem Axle Silage Cart (A50774)
Tandem Axle Silage...
2021 John Deere C450 (A50120)
2021 John Deere...
