Rotary Cutter Land Pride 2072RCF or Rhino 172 Rotary Mower???
   / Land Pride 2072RCF or Rhino 172 Rotary Mower??? #1
sjm1580
Southwest Florida
Kubota L5740HST, Takeuchi TL220, Kubota zd221
I am about to pull the trigger on a rotary cutter and these two are at the top of my list. I am leaning towards the Land Pride 2072RCF as it is $130 cheaper and I can order parts online from Messicks, but wanted to get opinions on my choices.
I have 10 acres that I want to maintain, so I will be mowing heavy grass, small brush (up to 1 inch dia.), so I'm sure these two would handle the load. There are no Woods dealers close to me so that ruled out them. I could also get a Bush Hog BH16 for about the same price as the Land Pride, but have read mixed reviews on it.
As always, thanks for the help!
Steve
Steve
OK, am I just looking at different shades of grey?
   / Land Pride 2072RCF or Rhino 172 Rotary Mower??? #3
I looked at weight, gearbox hp, tip speed, and $$. And ended up getting the Rhino 172 a couple years ago. It is holding up well and does a nice job with my native grass CRP and weeds/ brush around the edges.
   / Land Pride 2072RCF or Rhino 172 Rotary Mower??? #4
I have a LP 2060 that I'm generally happy with. I don't necessarily care for the PTO coupler style or the tail wheel adjustment. I have an older Rhino (possible SE4?) on a smaller tractor and I like the PTO coupler better (twist a ring to open the coupler) and the tail wheel height is changed by moving two pins (no tools). On the Land Pride, you pull back the coupling collar while pushing the coupler into the PTO shaft, kind of a pain to pull and push on something at the same time and you have to break out a wrench to adjust the tail wheel height.
Another thing to note is how smooth the underside of the deck is. On the Landpride, the top of the deck is very smooth and free of supports, this is at the expense of the supports being under the deck, where you actually want it smooth for better cutting and distribution and less places for rust to start.
Made a deal on the Land Pride today. Looked at both the Land Pride RCF2072 and the Bush Hog BH16 at the dealer, decided to go with the Land Pride but could have gone either way. Both looked good, little difference to tell you the truth (shades of grey).
   / Land Pride 2072RCF or Rhino 172 Rotary Mower??? #6
. . . Another thing to note is how smooth the underside of the deck is. On the Landpride, the top of the deck is very smooth and free of supports, this is at the expense of the supports being under the deck, where you actually want it smooth for better cutting and distribution and less places for rust to start.
That's what sold me on the Rhino 172. I want the underside smooth so that it's less likely to build up cuttings and crud under there. The top of the deck is easy enough to blow off with a leaf blower; the underneath side would be a PITA to clean.
(1) HD 24ft Free Standing Corral Panel (A51572)
(1) HD 24ft Free...
2017 Bayliner VR5 21ft Bowrider Boat with 29ft T/A Boat Trailer (A51694)
2017 Bayliner VR5...
LOT NUMBER 146 (A53084)
LOT NUMBER 146...
2001 International 4700 Dump Truck with Compressor, VIN # 1HTSCAAN91H363922 (A51572)
2001 International...
2021 Honda Foretrax Rancher (A51573)
2021 Honda...
New/Unused 48in Quick Attach Pallet Forks (A51573)
New/Unused 48in...
