Getting rid of old gas.
   / Getting rid of old gas. #32
I wouldn't use straight gas, old or new, to start a fire. Even mixed with motor oil or diesel it will still flame up if the gas is still volatile. l left some untreated gasoline in my zero turn once and the next spring it wouldn't start or even backfire. I poured out the old gas in the gravel in front of my shop, threw a match on it and it didn't light, after several matches hit in the pool and wouldn't lite, I had to try something else. I got my propane torch and heated the gas up for a few seconds and finally got it to start burning and it smoked like burning an old tire. I could sure see why the lawnmower engine wouldn't start with it in the tank. Luckily we new gas in the tank, it started right up so I lucked out with no carb repair needed.
I have since never stored engines with untreated gas in them. A double shot of Red Stabil keeps the gas usable next spring. I do try to only put a small amount in the tank, less than 1/4 tank then fill the tank in the spring with fresh gas. For small engines like a push mower, I drain the tank and store them dry.
   / Getting rid of old gas. #33
What I do with gas that is getting old (like 3 months old) is that I put that in my trucks fuel tank, as much as I have. It doesn't seem to bother the fuel injected truck. I try to use up my gas before it is more than 3 months old and all of it starts getting Stabil toward fall when usage falls off. During summer months I fill up 2 -5 gal. containers and a 2.5 gallon at a time. It takes about 4 gallons to mow my yard each time so that is just about 3 weeks worth of fuel.
   / Getting rid of old gas. #34
Your (my) county landfill will will accept gas as a hazardous material. There will be a little higher charge hazardous material though.
   / Getting rid of old gas. #35
volatile. l left some untreated gasoline in my zero turn once and the next spring it wouldn't start or even backfire. y.
Did you check the kill switch?
While I have forgotten or been to lazy to use Stabil, in sleds, bikes, and mowers, and they all started the next year. I think it was bad to do, but they still started.
I use Seafoam often, but I also think gas must be better then it was 30 years ago.
flooring (A53424)
flooring (A53424)
2018 Chevrolet Silverado 3500HD 4x4 Crew Cab 9FT Flatbed Truck (A51692)
2018 Chevrolet...
2011 DOOSAN G25 GENERATOR (A53843)
2011 DOOSAN G25...
2007 MACK CV713 WINCH TRUCK (A53843)
2007 MACK CV713...
2012 LEEBOY 8515B APHALT PAVER (A51406)
2012 LEEBOY 8515B...
