5600 making engine oil black smoke
   / 5600 making engine oil black smoke #1
nort33
spokane wa
jd 300
hi all and thanks in advance.
Is there a preferred dealer you have good luck with buying injectors from?
   / 5600 making engine oil black smoke #2
Any decent diesel injection shop should be able to get them, as well as test the old ones, which is what I'd do first.
The shop I use only charges a small amount, think it's $7 to test an injector, and they discount that charge of you end up ordering replacements.
They might even be cheaper than ordering from a dealer. (Usually are)
   / 5600 making engine oil black smoke #3
What does blue smoke coming from the exhaust mean ? My tractor has recently started smoking and the smoke is blue. I forgot to tell eeryone that it is a Mahindra 4025.
Thanks dt86 😎 I was going to use a supporter of the form if possible just to show love.
I called around and there's a diesel shop in Spokane that will test and to rebuild is $27 plus parts two day turnaround.
I don't know about blue smoke.try posting straight to the form.
I know white is coolant black is excess diesel.
Good luck
   / 5600 making engine oil black smoke #6
Thanks dt86 I was going to use a supporter of the form if possible just to show love.
Got it.
That seems like a very fair price.
   / 5600 making engine oil black smoke #7
Thank you and I'll ask some of the shops in the area about this. The tractor doesn't have but 600 hours on it and I bought it new.
   / 5600 making engine oil black smoke #8
Blue smoke is typically engine oil being burnt. There are many reasons why it can happen. Check the oil level for over-fill and verify the oil used is correct for your machine.
Start a thread under the Mahindra heading and you'll get more attention from folks who own and run the same tractor as you.
   / 5600 making engine oil black smoke #9
Good luck
Thank you and I might just do that.
2015 KENWORTH T800 DAY CAB (A53426)
2015 KENWORTH T800...
2016 Autocar Xpeditor T/A New Way Side Loader Garbage Truck (A51692)
2016 Autocar...
Modine Shop Heater (A51573)
Modine Shop Heater...
2006 JLG 460SJ Man Lift (A51573)
2006 JLG 460SJ Man...
