Outside Water Spigot - Fail
   / Outside Water Spigot - Fail #11
yes he did
   / Outside Water Spigot - Fail #12
My money says its soldered to the copper inside, and nothing will unscrew.
Either gain access inside to replace, or use a shutoff like suggested. I see in the pics you already have a double shutoff adapter on there. Does that not work or is it leaking elsewhere?
   / Outside Water Spigot - Fail #13
Put the hose on it. Then put a nozzle on the hose that will shut off. at least a temp patch. Me lazy & like the easy way out. :laughing:
Screw another shutoff valve on it. When you want to use it, remove valve and attach hose.
I've attached one of those y adapters to it. This has two ball valves in it too and for now I just keep them both closed. So, although it's a pain in the neck, we can keep the house water on until I have a repair solution.
   / Outside Water Spigot - Fail #15
Have you taken the blue handle off to see if you can access the internals?
I am betting that it is a screw on. My only hope/justification is that I am having difficulty imagining the plumber doing the soldiering in that location.
Yup, that is working so far. With all the other things going on here it will probably be that way until fall. Then I will be forced to change it out before a freeze since there is no way to get the water out of it with the current valve setup on it.
Yep, we have had it apart to replace the seal on the end of the stem and to replace the packing. That was several years ago and the hardware store owner said at that time that there are no parts made for these any longer.
I like your thinking. Assuming the drywall work was done after the pipes were installed. Probably the same guy who designed the oil filter location on my truck. (that's a joke.)
Went shopping.... Looks like the replacement faucets are available in both sweat on or threaded versions. That means "Murphy" is probably lurking in my closet and as soon as I try to unscrew the old one he will pop out and say "You just twisted the copper sweat joint and now you are going to cut open the drywall." LOL! Oh well, it will be worth a try anyway, there are two of these on the house so we'll learn on this before doing the other. This one is at least easily accessible inside the house through the drywall inside the closet. The other faucet is located on a wall that is behind the washer and dryer but still not accessible without cutting a hole in the drywall.
If I learn the first one to be threaded then I have a better chance of replacing the second one without cutting a new hole to patch.
   / Outside Water Spigot - Fail #19
If he puts a shutoff downstream of tune drip that defeats the purpose of a frost free and he'll have bigger problems next winter if he gets freezing temperatures.
Sheetrock on opposite side? He is looking in the basement right? Even if a finished basement, it should be in the ceiling. What do I know?
I suspect there's a nut under that blue handle that allows the core/ stem to be removed.
When I had them bust, it was easiest to just by a new frost free valve of the same length, and swap the guts of the new with the old, rather than replacing the outer valve body and especially its connections to the house pipes/peck.
I suspect there's a bit under that blue handle that allows the core/ stem to be removed. When I had them bust, it was easiest to just by a new frost free valve of the same length, and swap the guts of the new with the old, rather than replacing the outer valve body and especially its connections to the house pipes/peck.
Not sure what our house is formally called but the downstairs is not really a basement, only partially below grade. Maybe "split-level" or something like that. In any event the ceiling of the first floor is a normal sheetrock ceiling just as on the second level. The valve is outside the closet of a bedroom on the first floor. So the sheetrock is in an area that wouldn't require a lot of fancy finishing afterwards although I am too much a perfectionist to not do it right.
Unused 2025 LandHonor LDH-KN16 Mini Excavator (A52377)
Unused 2025...
BUSH WACKER ST-180 ELITE BATWING ROTARY MOWER (A51406)
BUSH WACKER ST-180...
2018 CATERPILLAR 303.5E2 CR EXCAVATOR (A52705)
2018 CATERPILLAR...
greenworks (A53421)
greenworks (A53421)
JOHN DEERE 560M LOT NUMBER 15 (A53084)
JOHN DEERE 560M...
