Old plow behind Kubota
/ Old plow behind Kubota #1
mopower01
Member
PA
Bolens, Kubota B8200dt
I picked up an old horse drawn plow at a flea market this past weekend. My girlfriend wants to decorate with it, but I thought I might be able to use it to plow my garden by pulling it with my tractor. Has anyone else done this? Any ideas on how to attach it? I was thinking of using the 3pt hitch to raise and lower it some how, but I haven't sized things up yet.
/ Old plow behind Kubota #2
Hook it with a chain and have you girl friend walk along and guide it. :D Ed
/ Old plow behind Kubota #4
Just yolk the GF. :confused3:
/ Old plow behind Kubota #5
Isn't that backwards?
Bruce
/ Old plow behind Kubota #6
Really need to see picture of girlfriend to advise further ;)
/ Old plow behind Kubota #7
+1.
There's harness available for her too.
I've seen it on the interwebs... it looks good but I don't think it's very practical for this application.
/ Old plow behind Kubota #8
Many years ago, we converted a 2 bottom, drag type plow to a 3 point hitch hookup. I believe it is a heavier, better plow than most new ones you see today.
/ Old plow behind Kubota #10
No if they pulled it in the other direction it would not dig in, it would just slide on top of the ground. :D Ed
The wolp is a pretty rare implement, used to fill furrows.
Bruce
Ok, all kidding aside, I took off my top link and attached it with a couple clevises. I have a bar between the hitch arms to pick it up with 2 uprights to limit the side to side movement. I tried a pass with it and it just skimmed the ground. I think I may have to add some weight to get it to dig in, or maybe I need to lower the attachment point?
/ Old plow behind Kubota #12
If you get the attachment point at the right height it will work. Did you notice the row of holes in the end of the beam? That is how fine of an adjustment you need. Look at a pic of someone plowing with a horse and see how high it is from the ground. Ed
/ Old plow behind Kubota #13
If it has wheels just hook it up with what you got. Then you have to adjust the plow. It should have a wheel driven lifting device built in. Google for pictures.
If it has two handles on the back don't even consider, just derust, paint for lawn ornament.
/ Old plow behind Kubota #14
If you are into self flaggelation show your wife this picture.
[video]https://www.google.ca/search?q=duckabours+pulling+plow&client=safari&hl=en-ca&prmd=ivmn&source=lnms&tbm=isch&sa=X&ved=0ahUKEwihoKnbq5PNAhXr54MKHRzJA_MQ_AUIBygB&biw=1024&bih=681#imgrc=OiSze7hWGpwqlM%3A[/video]
It used to have 2 handles but they were missing when I bought it. What I have is a John Deere 330. All there is for adjustment are a series of holes at the end of the arm.
I like what you did with yours, but i don't want to go quite that direction with mine. I tried mine out again last night and I think it is still mounted to high. It doug in a little better but still just scraped the grass off the top. even tried standing on it.....nothing. I watched a couple horse plowing videos and their plows are hooked really low. I may have to got to the drawbar.
/ Old plow behind Kubota #18
Is your John Deere plow something like this?
We attached this type to an AC-WD45 tractor with a short chain. The guy steering the plow was new at it and it tired him out fast and the garden was tilled by the neighbor the next week.
That is what I have....less the handles.
KUBOTA MI08S TRACTOR (A63276)
KUBOTA MI08S...
2020 Kubota M7-131 Premium Tractor (A64047)
2020 Kubota M7-131...
New/Unused 7ft Fork Extension (A61166)
New/Unused 7ft...
2019 KUBOTA KX057-4 EXCAVATOR (A62129)
2019 KUBOTA...
PALLET OF (3) BURNER GAS COOKER (A62131)
PALLET OF (3)...
New/Unused 13,000lb Electric Winch (A61166)
New/Unused...
