dstig1
Super Member
- Joined
- Apr 7, 2010
- Messages
- 5,059
- Location
- W Wisc
- Tractor
- Kubota L5240 HSTC, JD X738 Mower, (Kubota L3130 HST - sold)
I've got a Robin/Subaru engine on my splitter (Super Splitter) and it is now giving me trouble. I started it up a couple months back as it had sat a while and I wanted to make sure it was working. Started and ran great for 5 or 10 min. Flash forward a few weeks and I had a friend come over to help me split some wood. Now it wouldn't start. We were able to get it running with some carb cleaner shot in the intake, so it was clearly a fuel delivery problem. Finally decided the carb must be a bit plugged up, so i soak it in Seafoam for a week or two put it back together and it starts right up. But then the RPMs started to take off. I thought maybe I damaged the gaskets on the carb by taking it apart a billion times while messing with it, so I got new gaskets and put them in today (assuming an air leak after the carb, for example). Same problem - RPMs shoot way up and the governor does not seem to be doing anything. The throttle does almost nothing - it won't idle down at all. The governor linkage is moving perfectly easy and is connected correctly, but the linkage never moves on it's own now when the engine is running. I can move it by hand and it does what it is supposed to while running.
I'm at a loss. I have no idea how it could work perfectly and now come down with all these problems so soon after that. And I have no clue what might be wrong with it now. I haven't done much with small engines other than cleaning out a carb on occasion, so I am in the dark here. Anyone have any clues?
Thanks,
Dave
Thanks,
Dave
