Info on Routine Maintenance 1652
   / Info on Routine Maintenance 1652 #1
DC1652
saskatchewan, canada
MF1652
Hi
First time poster and first time tractor owner...
Purchased used 2012 - MF 1652 (500 hrs) but didn't come with owners manual. Can anyone direct me to a place where I could get a primer on changing fluids, grease points .. and any other general PM's required to keep the tractor in operating condition and away from any major repairs
By the way, I don't know if it matters but it is a Qs series 12 speed ... shuttle shift
Thanks
   / Info on Routine Maintenance 1652 #2
From my phone notes:
Massey 1652
-Engine oil, 10w-30 or 5w40, 8.5 qts, 3/4 drain bolt.
-Coolant: 8 Qts (7.6L)
-Hydraulic oil: 7/8" drain bolt, 8.2 gal. Permatran III (OR Mobil424, Permatran 821xl, Kubota UDT, Deere Hy-Gard J20a, c, j21a... Case Hy-Tran plus, ultra ETC).
-Front axle Permatran III, 6.2 qts, 11/16 bolt.
Oil filter:
Mobil 1 #M1-102
AGCO #3757038M2
ISEKI #6213-240-005-1
DENSO #115010-5250
NAPA #1348
Hydraulic filter:
AGCO #3608996m91
Napa #1664 ($13)
Fleetguard #HF28850
Donaldson #P556005
Wix #51664
Air Filter (cabin):
PF-16892 (6243528M2)
   / Info on Routine Maintenance 1652 #3
Grease points are all pretty obvious, only sneaky ones are the front axle pivot joint, and there's one up under the HST pedals (might be a similar zerk for the Gear models).
Also, I have a thread in here regarding hydraulic maintenance... There are removable, cleanable metal-mesh hydraulic filters underneath the machine. Look up that thread to see what I'm referring to.
   / Info on Routine Maintenance 1652 #4
Massey 1652
Oil filter:
Mobil 1 #M1-102
AGCO #3757038M2
DENSO #115010-5250
NAPA #1348
Hydraulic filter:
AGCO #3608996m91
Napa #1664 ($13)
Fleetguard #HF28850
Donaldson #P556005
Wix #51664
Air Filter (cabin):
I have a different model Massey but was curious how you cross referenced the Agco filters to other brands?
   / Info on Routine Maintenance 1652 #7
Been away for a few days. Many thanks for this great info. Would I be correct to assume that the 1652 HSTC filters are the same as for the 1652 Q series
   / Info on Routine Maintenance 1652 #8
I believe the HST models have an additional filter
   / Info on Routine Maintenance 1652 #9
Also if anyone has a used manual for the MF 1600 series (1652 specifically) for sale, please send me a message ... many thanks
   / Info on Routine Maintenance 1652 #10
I'll snap photos and post them
Kivel Q.A Pallet Forks (A50121)
Kivel Q.A Pallet...
Case SC Tractor (AS IS) (A50774)
Case SC Tractor...
Yamaha 4-Wheeler (A50121)
Yamaha 4-Wheeler...
Miles read : 112,969 (A50323)
Miles read ...
2017 Big Tex 10ET T/A Flatbed Equipment Trailer (A50322)
2017 Big Tex 10ET...
2012 Bobcat S850 (A50120)
2012 Bobcat S850...
