1968 ford 4500 coolent leak at injector
   / 1968 ford 4500 coolent leak at injector #1
silvereagle68
Bloomfield,Ct.
1968 ford 4500
I have a problem I was trying to get my tractor running with ether I think I did some damage because coolent started leaking out of the radiator cap and then out of number 3 injector does any one have any idea if I cracked the head or maybe head gasket problem
   / 1968 ford 4500 coolent leak at injector #2
Sounds like one or both has happened, ether just isn't good for them
   / 1968 ford 4500 coolent leak at injector #3
I'm thinking the same as JD. Were you spraying ether while cranking it over or did you spray, then crank? At a minimum I'd say the head gasket is toast. When you have the head off, have it checked for cracks.
2023 LMC M40018 LOT NUMBER 176 (A53084)
2023 LMC M40018...
Guard Rail Pieces (A51692)
Guard Rail Pieces...
New Long Forks (A53002)
New Long Forks...
New/Unused Fuel Pump with 50ft of Hose (A51573)
New/Unused Fuel...
2018 TAKEUCHI TB290 EXCAVATOR (A51246)
2018 TAKEUCHI...
