How to adjust rear pto clutch 4120
   / How to adjust rear pto clutch 4120 #1
jtfx6552
West Chester, Pa
John Deere 4120
I tried searching... ""adjust pto clutch 4120" brought back 1700+ results in just the JD owning operating forum, went through 5 pages and couldn't find what I'm looking for.
My LX6 mower blades stop in high grass. My pto shaft cover is loose, so I can see it's the PTO shaft that stops turning. I'm packed up to move and can't find my manuals. Is there a way to adjust the clutches that turn the pto output shaft?
Machine is a ehydro if that matters, 2004 with 400 hours.
   / How to adjust rear pto clutch 4120 #2
4120 pto clutch is hyd with no adjustment except changing hyp pressure. It sounds as if slip clutch if so equipped on LX6 is slipping. I Tighten each nut 1/2 turn until clutch stopped slipping.
Thanks! I originally thought it was the clutch in the mower, but since my PTO cover is broken, I can see that the PTO shaft stops at the tractor. Are you saying the clutch isn't really a clutch, but the PTO is turned directly with hydraulic pressure, or their is a clutch pressed together with hydraulic pressure?
   / How to adjust rear pto clutch 4120 #4
The clutch is engaged hydraulically via a clutch valve and series of wet disc and plates. Pressure tests are probably needed to identify the problem if it the tractor that it slipping.
   / How to adjust rear pto clutch 4120 #5
Ditto what Morrisonsteel stated.
Do you happen to know if the gauge port locations, the required pressures and adjustments are shown in the manual that came with the tractor? If so, I'll start tearing into boxes to find the manual, lol.
   / How to adjust rear pto clutch 4120 #7
The op's manual that came with the tractor will not have that information in it, you will need access to a tech manual.
   / How to adjust rear pto clutch 4120 #8
Shoot me your email, I have a PDF of the tech manual you're welcome to
Joe
2007 International 7400 Chassis Truck, VIN # 1HTWGAAR87J437650 (A51572)
2007 International...
2019 MITSUBISHI OUTLANDER SPORT (A52472)
2019 MITSUBISHI...
2005 Toyota Tundra Limited Crew Cab Pickup Truck (A51692)
2005 Toyota Tundra...
2016 Land Rover Range Rover Sport AWD SUV (A51694)
2016 Land Rover...
2015 Infiniti QX60 SUV (A50324)
2015 Infiniti QX60...
2011 GMC Sierra 4x4 Pickup Truck, VIN # 3GTP2WE36BG213306 (A51572)
2011 GMC Sierra...
