Will I damage a hose if I clamp it shut to do a cylinder leak down test?
   / Will I damage a hose if I clamp it shut to do a cylinder leak down test? #1
lhfarm
Central Indiana
NH TC40DA
I know the normal method is extend the cylinder, then remove the hose to test for leak-down. I don't have a disconnect or any method to remove the hose while maintaining pressure. Will I damage the hose if I us vice grips or clamps to act as the disconnect?
Thanks,
   / Will I damage a hose if I clamp it shut to do a cylinder leak down test? #2
Thanks,
I think so yes.
   / Will I damage a hose if I clamp it shut to do a cylinder leak down test? #3
Yes you will damage the hose. You will also have no idea whether it is completely pinched off. I do leakdown tests with a non-contact infrared thermometer without any other tools. 100% effective when done properly.
   / Will I damage a hose if I clamp it shut to do a cylinder leak down test? #4
Do you want to know if the cylinder is leaking internally?
   / Will I damage a hose if I clamp it shut to do a cylinder leak down test? #5
Rick
Would you please explain your procedure for using infrared thermometer for this test?
Thanks,Jim
Yes. Trying to determine if the cylinder or control valve is leaking. Lift drops even when the jeep is running, so assuming it is the cylinder.
I too would like to hear about Rick's test.
   / Will I damage a hose if I clamp it shut to do a cylinder leak down test? #7
Best to start with a cold system. Start power unit, extend or retract cylinder fully, whichever is most convenient.
Hold system over relief for brief periods, on/off so as not to overheat oil supply or damage pump. Two or three minutes of cycles is usually sufficient
Oil rushing over a failed piston seal will warm the cylinder barrel in the area of piston contact.
As little as 5 to 10 degrees temp differential at the piston proves a failed piston seal.
Some piston seal failures leak only one way, it may be necessary to test in both directions.
Great for diagnosing loader cylinder failures where it is not cost effective to rebuild or even disassemble two cylinders when one has failed.
No oil spilled, no wrenches, no dirty hands.
Absolutely never had a false positive result with a $50 IR gun. Will also pinpoint valve problems by eliminating a cylinder as a culprit.
   / Will I damage a hose if I clamp it shut to do a cylinder leak down test? #8
Single acting or double acting cylinder?
Single action - but this is an antique cylinder on my 1949 Jeep. Instead of a drain or breather, it has a hose at the bottom, which empties into the top of the reservoir. Long story, but it lifts great, but starts to drop immediately. Thanks for this great tip. I'll do some testing and get back to you.
   / Will I damage a hose if I clamp it shut to do a cylinder leak down test? #10
Why not just disconnect the bottom hose and see if any fluid comes out of it?
Aaron Z
1618 (A57192)
1618 (A57192)
JOB BOX W/ 100K X 20' NYLON SLINGS (A54757)
JOB BOX W/ 100K X...
KUBOTA ZG1235 ZERO TURN MOWER (A57192)
KUBOTA ZG1235 ZERO...
2024 BOBCAT MT100 STAND-ON SKID STEER (A52707)
2024 BOBCAT MT100...
BFH 1000 BALANCE FORCE HARMONICS TIRE BALANCER (A54757)
BFH 1000 BALANCE...
2016 JOHN DEERE 323E SKID STEER (A52707)
2016 JOHN DEERE...
