Will I damage a hose if I clamp it shut to do a cylinder leak down test?
   / Will I damage a hose if I clamp it shut to do a cylinder leak down test? #21
If the cylinder is leaking internally it won't. But if the valve is leaking, it will. It is how you isolate the problem. Some of you wonder why people are not willing to help. Hummm, I wonder? CJ
Typical installations like that use low pressure hose and connections for the drain/overflow. I guess the first indication of a valve problem would be when the drain hose blew apart.
   / Will I damage a hose if I clamp it shut to do a cylinder leak down test? #22
I guess I should have explained better. Ball valve goes in the cylinder base end or pressure line with a single acting cyl. That works really well on a double acting cylinder also, it is safe and lessens the chance of injury. Sorry should have been more wordy! CJ
   / Will I damage a hose if I clamp it shut to do a cylinder leak down test? #23
Thanks, but I'll keep using my IR gun.
2014 MACK ELITE LEU613 GARBAGE TRUCK (A57192)
2014 MACK ELITE...
Cowboy Wooden Statue (A55853)
Cowboy Wooden...
2013 RAM 4500 (A50323)
2005 Nissan Frontier Crew Cab Pickup Truck (A55852)
2005 Nissan...
2018 Chevrolet Tahoe SUV (A55853)
2018 Chevrolet...
2010 Ford F-750 Stellar 10621 10,000LB 5 Ton Crane Mechanics Truck (A51692)
2010 Ford F-750...
