ZD1211 or F2690
   / ZD1211 or F2690 #1
hdalan
Advice needed. I'm trying to decide between ZD1211 and F2690. Currently I use a ZD21 which is a very good mower. The problem I have is that my lawn is very rough and I am tired of getting beat to death. The question I have does have experience with both and would the F2690 offer a better ride than the ZD1211?
   / ZD1211 or F2690 #2
I have the F2680 which is the same as the 2690 and a new ZD1211. I find it hard to tell the difference in ride. The ZD has a better seat then my F but they are comparable in ride. Both have their advantages and drawbacks. As for the ZD21, it has small tires compared to the 1211 so it will ride rougher. I let most the air out of the rear tires in mine so that may help with the ride.
   / ZD1211 or F2690 #3
Once you have an F series Kubota you would find it tough going back to a ztr.I sold a Hustler fastrack and bought my F3680 and only wish i had done it sooner! Mowing is definitely easier on the body and i find having the deck out front has much better visibility.I have used a friends ZD331 which has the same size deck as mine and i much prefer the F for comfort..just my two cents worth!!
   / ZD1211 or F2690 #4
I've owned 3 different Fs and currently still own one F3080 72" rear discharge. I bought one F2680e new, used it on flat rental property, traded it to a new F3080 and then later bought it back and since then have traded it to a ZD326 for the flat rental property. Also bought a small Z for home property which is mostly hillside but with some level. It was bought for my wife to help me mow some at home. T Z can't hack hillside property, only the F3080 4wd does it safely.
The Z on rental property is faster around rental units but falls behind the F on the open field areas and getting up under trees/shrubs. The Z bounces all over the rough level field with constant movement of handles to keep it straight at speed where the F will move on out and keeps itself fairly straight. Both ride about the same with the suspension seat being the same on both. Put a suspension seat on the small Z at home and wife loves it.
Mowing parking lots will be the same on both but in the real world of steep land and rough land the F is the winner hands down from my own hands on experience with both on the same property over the past 8 years. Only had the Z for almost 2 years with son in law mostly using the Z and saying about the same as me with his experience.
   / ZD1211 or F2690 #5
I echo John Thomas, having had a ZD326 and now an F3680, especially slopes. The F is fast.
I'll add......the Z had left a ring around just about everything. And I tried to be very easy going around things, still did it. With the F most of that has stopped. My technique for trimming around things is different with the F, a tad slower, but the results to me is better.
   / ZD1211 or F2690 #6
One more comment, you will feel like you have done arm exercises with the ZD. Nothing beats a steering wheel for ease of steering.
But I do have to dispute the ride. Maybe its the large diameter tires on the new ZD but I can't say it rides worse than my F.
   / ZD1211 or F2690 #8
I'm going to be another vote for an f series.
I recently purchased an f3060 and I'm loving it. Once I got the suspension seat adjusted properly I find the ride to be easy on my back and arms. It's a little slower them a zero turn in tight areas but in open fields it sure mows fast.
   / ZD1211 or F2690 #9
After running both for a bit now I find the Z turn with the suspended deck scallops worse in uneven terrain. The front mount follows contours better. I wish they would make a ground contact deck for z turn but maybe they wouldn't stand up.
   / ZD1211 or F2690 #10
I found that out too. I get a better cut with the F than the Z.
New/Unused 7ft 8 Drawers and 8 Cabinets Workbench (A51573)
New/Unused 7ft 8...
2008 Ford Escape XLT SUV (A51694)
2008 Ford Escape...
2008 Chevrolet Impala Sedan (A51694)
2008 Chevrolet...
2007 DELTA TRAILER (A52472)
2007 DELTA TRAILER...
2021 VemaTEC 30in Excavator Bucket (A51691)
2021 VemaTEC 30in...
Peterbilt 377 Semi-Truck (A53472)
Peterbilt 377...
