Pressure washing plastic lawn chairs back to new.
   / Pressure washing plastic lawn chairs back to new. #1
sixdogs
Super Star Member
Ohio
Kubota M7040, Kubota MX5100, Deere 790 TLB, Farmall Super C
Maybe I'm the last to know but I was pressure washing some equipment and decided to try it on some grungy lawn furniture from the barn. It was really nasty with years of dirt, grime, grease and whatever but the pressure washer cleaned it back to new in mere moments. The results were so shocking I took a picture. OK, two.
I used a turbo nozzle if that matters.
I have no idea why the pictures are sideways because they were straight when I loaded them.
   / Pressure washing plastic lawn chairs back to new. #2
What kind of pressure washer? A big high pressure/flow gas engine one? or one of them little 1600-1800PSI electric ones for $100?
Have used both. Like the big one for cleaning equipment, blowing off grease and grime, etc. But them little ones are nice for washing stuff like you just did, vehicles, etc.
   / Pressure washing plastic lawn chairs back to new. #3
I discovered this a few years ago. It works great. You have to keep the pressure down though, otherwise those lightweight chairs will end up in the neighbors yard.
   / Pressure washing plastic lawn chairs back to new. #4
I have been doing that for years. Don't have a turbo nozzle. Just an old 2700 psi pressure washer. It really takes the grunge off of them.
Well, it is a high pressure, high volume one but I had it idled down and on low PSI to clean them. Otherwise, as KennyG states they would be long gone. Low pressure worked great. k0ua--try a turbo nozzle--they clean softer items great.
   / Pressure washing plastic lawn chairs back to new. #6
Most come with a selection of nozzles rated by color in decreasing level of aggressiveness...red, yellow, green, white, black (or is it black/white). Start at the low end and work up. No more intensity than required! Great tools.
   / Pressure washing plastic lawn chairs back to new. #7
The black tip on mine is used when you desire the cleaning fluid to be drawn from the tank into the pressure stream. The other tips are "water only."
Sent from my iPhone 2.0 using TractorByNet
   / Pressure washing plastic lawn chairs back to new. #8
I think the color is universal...makes sense (e.g. "red" means you have the equivalent of a sandblaster, yellow a step below that, green pretty safe for most things...just like stop-lights!).
There was no need of any cleaning soap or whatever. The grime was gone the moment the pressure hit the chair. Wife was so impressed she wants all the chairs from the barn done tomorrow.
   / Pressure washing plastic lawn chairs back to new. #10
Now there will be no stopping you wife! She is making a cleaning list for you as we type!
2015 MACK CXU613 (A53843)
2015 MACK CXU613...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
2019 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A54607)
2019 FREIGHTLINER...
2007 Honda CR-V SUV (A53424)
2007 Honda CR-V...
2007 MCDANI TRI AXLE STEP DECK (A53843)
2007 MCDANI TRI...
2006 International 9400i (A55218)
2006 International...
