2006 Ford F-150 rear pinion gear failure !!!
   / 2006 Ford F-150 rear pinion gear failure !!! #1
coobie
Super Member
S.Michigan
Kubota RTV 1100c, JD 740,Kioti DK 40 with KL401 loader .
Going down the road the other day started to hear a whine coming from the rear of my 2006 f-150 (3.73) gears low and behold the rear pinion gear is shot at 110,000 miles.Is this normal mileage for it to take a crap?I am meticulous at doing maintenance changed the front & rear differential fluid every 30,000 miles.I do not very tow heavy or hot rod my truck(old fart).
   / 2006 Ford F-150 rear pinion gear failure !!! #2
Did you have a pinion seal leak or change the seal at some point?
It's a rare failure that's for sure. I bet somehow the preload on the pinion bearing because loose and caused too much play in the pinion.
   / 2006 Ford F-150 rear pinion gear failure !!! #3
Don't take this the wrong way but I don't know anyone that changes differential fluid every 30k miles. Are you sure about that?
Googled ford TSB,s and found this TSB-05-12-6 I guess it is more common than I thought.Yes I have it changed every 30,000 miles maybe to **** about service.LOL.No leaks since I have owned the truck.I bought it with 35,000 miles on the OD..
   / 2006 Ford F-150 rear pinion gear failure !!! #5
Do you have a teenage son.....
   / 2006 Ford F-150 rear pinion gear failure !!! #6
I have been around Fords my entire life and have yet to see a pinion gear failure. For that matter in any brand.
Just bad luck I guess...
Chris
   / 2006 Ford F-150 rear pinion gear failure !!! #7
My guess would be that the bearing failed, either pinion or differential that threw the clearances off. The incorrect clearance then caused the gears to eat themselves. Regardless, the shrapnel from the failed gears would necessitate the replacement of the bearings. It might be overkill, but I'd replace the bearings at the axle ends too, just because they're suspect too.
2000 John Deere 1860, 30ft Wide, Gandy Box, Wing Fold, 7.5in Spacing (A53472)
2000 John Deere...
2004 Freightliner FL112 Cab & Chassis (A47384)
2004 Freightliner...
2019 FREIGHTLINER CASCADIA SLEEPER TRUCK (A52577)
2019 FREIGHTLINER...
New Skid Steer Attachment Plate (A53002)
New Skid Steer...
UNUSED FUTURE 1R RIPPER (A51248)
UNUSED FUTURE 1R...
Electric Mobility Scooter (A51694)
Electric Mobility...
