Throittle Issue
   / Throittle Issue #11
How big of a mower
   / Throittle Issue
Hydro level is fine, mower is 6' Bush hog...
   / Throittle Issue
My dealer just reached out to me with this:
Chris I have spoken to a service rep he wants me to reprogram throttle and check throttle cable location on fire wall
I'll let you all know how it works...please keep me updated if you find something different!
   / Throittle Issue
He worked on it and here's what he said...
Hi Chris I work on tractor I believe I fixed throttle problem I rerouted throttle cable it had a very sharp bend when it came out of fire wall after it got warm I could see ware it might collapse and not let it travel full distance I'll be back out on Friday to reset the ecu I made the MIL light come on didn't have my computer with me Thanks Todd
We'll check her out this weekend I guess!
   / Throittle Issue #15
Is he going to refllash ECU or just reset it to clear MIL?
Thanks
F J
   / Throittle Issue #16
Thanks
F J
A reset is usually just clearing the codes and the check engine light. They will often reset by disconnecting the battery for a few minutes or of course using your own scan tool. Scan tools are cheap enough that everyone should own one for their tractor, cars, trucks, etc. Every car and most trucks produced since 1996 has OBDII or CAN so it wouldn't be wasted. I have two and keep one of them plugged into the truck where it supplies info for gauge readouts that I wish the truck had from the factory.
   / Throittle Issue #17
dickfoster,
I suspected that it was simply a clearing of the MIL code and not an ECU re-flash that was being referred to.
However, as you said a code can be cleared by simply disconnecting the battery for a brief time, I couldn't see why he would make a special trip back with his computer just for that :confused: .
F J
   / Throittle Issue
Last time the MIL came up, I had a dirty EGR...he cleaned it and then reset the code, not re-flash.
   / Throittle Issue #19
dickfoster,
F J
I don't know if it works for Mahindra tractors but I know it does for my Toyota truck and most other cars and trucks. Before I got my first scan gauge that's how I reset the CEL. The trouble with using that method is that many ECUs self learn a bit by trimming the factory base maps over time. When you pull the power you reset the codes but you also lose all of that fuel and timing trim info so the ECU has to start trimming from the base map all over again. With a scan guage you can just read and reset the codes without losing any trim data.
   / Throittle Issue
Guys, I *assume* resetting of a MIL code would do nothing more than if you did the same thing in a car. After the vehicle goes through it's next cycle, it would trip again and come right back...
2015 Eager Beaver 15HBB-PT T/A Flatbed Equipment Trailer (A50322)
2015 Eager Beaver...
2016 Ford Explorer AWD SUV (A50324)
2016 Ford Explorer...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
RIGID TOOLBOX (A52472)
2015 INTERNATIONAL 28 PASSENGER HANDICAP ACCESSIBLE SHUTTLE BUS (A52577)
2015 INTERNATIONAL...
1989 Ford FT900 T/A Cab and Chassis Truck (A51692)
1989 Ford FT900...
