3000 gasser pours gas out of carb
   / 3000 gasser pours gas out of carb #1
Mtn.Mike
Northcentral Pa.
JD 2305
My 1972 started running really rough and I noticed gas pouring out of the carb. Since it was the original carb (Holley) I changed to a Zenith thinking the Holley was worn out.
Now the Zenith does the same thing. The tractor will start but despite moving the throttle there is no power advance just gas pouring out of the carb. I have tried to set the fast idle screw but there is no change weather I turn it all the way in or all the way out.
I can change the fuel feed to gravity and the tractor runs fine but due to the hills around here I want the gas to come from the pump and not gravity.
I have done everything I can think of to fix this but now I'm asking the forum for help.
Thanks, Mike
   / 3000 gasser pours gas out of carb #2
Typical failure would be something stuck under the carb inlet needle (float needle) or the float is defective. You will have to remove the float bowl and investigate.
   / 3000 gasser pours gas out of carb #3
Might be crude from the tank making the needle stick...
   / 3000 gasser pours gas out of carb #4
Try tapping on the side of the carb with a small hammer/wrench/whatever. See of the gas pouring out dont stop. If it does, the float/needle was stuck.
If it still pours out, Float could have a hole in it or be mis-adjusted, or seat worn out, or debris as mentioned, or just stuck so bad the tapping didnt fix it.
This is a brand new Zenith carb so that should rule out the above problems. I hooked up the carb for gravity flow from the tank and it runs fine. What gives?
   / 3000 gasser pours gas out of carb #6
I always have to set the float on a new install... maybe the float is not correctly set?
Be careful has extra fuel anywhere is a disaster waiting to happen.
   / 3000 gasser pours gas out of carb #7
If gravity feed works and with pump leaks, the pump is too strong. The pump should be no more than 1-2 psi. If it's adjustable, dial it down.
Why is there a pump?
   / 3000 gasser pours gas out of carb #8
I always have to set the float on a new install... maybe the float is not correctly set? Be careful has extra fuel anywhere is a disaster waiting to happen.
No joke there. A similar problem combined with design flaw burned my Dixie chopper.
Pump was original on the tractor. Gravity works well on level ground but when going up steep hills the gas tank is lower than the carb so no gas flows.
Another question is why does the tractor work with gravity flow and not with pump unless the pump is putting out too much pressure?
   / 3000 gasser pours gas out of carb #10
Pump was original on the tractor. Gravity works well on level ground but when going up steep hills the gas tank is lower than the carb so no gas flows. Another question is why does the tractor work with gravity flow and not with pump unless the pump is putting out too much pressure?
It is probably flooding it.
2016 RAM 5500 Bucket Truck - Cummins Diesel - Auto Trans - 4X4 - Terex LT40 Boom (A53473)
2016 RAM 5500...
Pallet of Lights (A53117)
Pallet of Lights...
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A51694)
iDrive TDS-2010H...
2023 Club Car Carryall 700 Utility Cart (A51691)
2023 Club Car...
2015 Chevrolet Silverado 2500 HD Crew Cab Pickup Truck (A53422)
2015 Chevrolet...
2007 Freightliner B2 School Bus (A51692)
2007 Freightliner...
