How to remove object fallen into Steering wheel compartment
   / How to remove object fallen into Steering wheel compartment #1
Willsk
Member
Harare
Massey Ferguson
I have a vaaljapie tractor and a metal object fell off the starter and fell inside, how best can i safely remove this object
   / How to remove object fallen into Steering wheel compartment #3
A magnetic pickup tool, long needle nose pliers might work.
If all else fails turn the tractor over and shake it good that worked for my cat last year.
   / How to remove object fallen into Steering wheel compartment #4
I don't know what your tractor is like but on my Kubota the dash and dash cowl come off very easily.
   / How to remove object fallen into Steering wheel compartment #5
For magnetic objects use a magnetic retrieval tool for non magnetic objects some chewing gum on a stick. Barring that, dynomite.
   / How to remove object fallen into Steering wheel compartment #7
I'm curious. Is Vaaljapie Ferguson in another language or is it a specific model of Ferguson? I believe the op lives in Zimbabwe.
   / How to remove object fallen into Steering wheel compartment #8
I dont know why its called a Vaaljapie, but it is a TO-20 Ferguson (export version of TE-20) as far as I know. The manuals are the same.
   / How to remove object fallen into Steering wheel compartment #9
If its a t?-20 the starter drive probably fell off in the bellhousing. A 3 jaw might get it.. But the flywheel and ring hear make it hard to see unless you have a borescope to go with it.
There is plenty of storage space down there, but occasionally the parts tide the ring hear and bust out a chunk of bellhousing.
   / How to remove object fallen into Steering wheel compartment #10
Thanks, Midniteoyl.
2016 Ford F-150 Pickup Truck (A55852)
2016 Ford F-150...
LINCOLN MIG WELDER (A55745)
LINCOLN MIG WELDER...
2023 54' Hooklift Dumpster 20 Cubic Yard (A53422)
2023 54' Hooklift...
2014 COMPTANK ACID TRANSPORT TRAILER (A55745)
2014 COMPTANK ACID...
2016 Ford F-150 Crew Cab Pickup Truck (A53422)
2016 Ford F-150...
KUBOTA M7-132 (A53084)
