1635 MF Water Pump Failure!!
   / 1635 MF Water Pump Failure!! #1
cpstrand
Belmont, N.H.
Massey Ferguson 1635LC
Good Morning to all, I have a 1635 with 550 easy hour one operator machine. Lost the water pump, asked dealer if common said haven't done or heard of any failures. They do stock the gasket seals though. New pump $640.00 anti freeze / coolant PH & protection all in specs. Any one have any sources for new pumps? Thank You in advance.
   / 1635 MF Water Pump Failure!! #2
You'll need to verify part numbers, but Jacks small engines has 3607154M93 for $530...
BUt look slike it can be had here for $187.
I also found a cross reference for part number M3607154N, which can be had for much less, again, you'll need to verify.
Thanks Fiziksgeek; Great information, I did some additional research & found a company in Arizona that does rebuilding of water pumps for everything on the planet. Kellogg Automotive in Maricopa, Arizona. Phone 1-877-499-2011 & another company in Houston Texas Commercial Water Pump Rebuilders Phone 713-864-5199. I will be in touch this week & get back with info on both. Thank You so much for your input.
   / 1635 MF Water Pump Failure!! #4
The dealer can't rebuild the pump? It's been years since i've had one rebuilt, just curious.
Ronnie
Hi MF283
Massey lists all rebuilding parts to do pump overhaul. Commercial Water Pump Rebuilders in Texas will rebuild my pump for $89.50 plus S/H. one day turn around. Kellogg Automotive / Water Pump Rebuilders in Arizona will Will rebuild my pump for $220.00 plus S/H. Two weeks turn around because of vacation time. I can buy a new pump thru All States AG Parts for $187.00 plus $12.95 S/H totaling $199.95. I decided to order a new pump thru All States AG Parts to get my tractor up & running & send my old unit to Commercial Rebuilders for rebuilding so to have a spare. Masseys prices weren't cost effective. Thank All for the info I recieved. Phil
   / 1635 MF Water Pump Failure!! #6
Phil
That sounds like a wise move.
Ronnie
cpstrand here,
New pump ordered wed. arrived sat am. great service from All States AG Parts. Opened box labled for my application factory pt.#3607154M93, there #M3607154N Hy-Capacity & 152225. Inside box 3757045M91 / 152224. This is a new pump made by Aisin. Called customer service at All States they were very helpful & puzzled on contents, will get back to me mon. am after talking to the supplier Hy-Capacity. They had more pumps in stock but didn't want to send another one out till finding out if packageing was marked wrong on all units. My cost was 199.95 to my door. Will keep in touch till corrected. Thanks to all who responded.
1997 Moxy MT30 Haul Truck (A55272)
1997 Moxy MT30...
VERMEER PD10 PILE DRIVER (A60429)
VERMEER PD10 PILE...
2018 Kaufman 20-Ton Equipment Trailer, VIN # 5VGAP2528JL004708 (A57453)
2018 Kaufman...
John Deere 853 20ft Corn Head (A56436)
John Deere 853...
New/Unused 8 Piece CFG Industrial Mini Excavator Attachment Set (A57454)
New/Unused 8 Piece...
2017 Ford Explorer AWD SUV (A56859)
2017 Ford Explorer...
