Farmtrac 535, correct position of loader to check hyd. fluid?
   / Farmtrac 535, correct position of loader to check hyd. fluid? #1
grandpawj
Member
Lancing, TN
Farmtrac 535 W/ 5245 front end loader(turf tires), MFG 2006
I need to check the fluid level in my Farmtrac 535. What should the position of my frontend loader be to check it? All cylinders extended or just sitting in the down position with buck curled up? I understand it can affect the fluid level in the rear, or does it?
   / Farmtrac 535, correct position of loader to check hyd. fluid? #2
Always check hydraulic fluid level of any tractor with the tractor on level ground, the FEL down with the bucket level on the ground and the 3pt all the way down as well. Tractor is to be level in all respects. Front to back and side to side.
Thank you Sir. Even though I'm old, I am still a novice.
2019 Ford F550 Bucket Truck - Powerstroke Diesel - Auto Trans - 4X4 - 72258 miles -Altec AT40G Boom (A53472)
2019 Ford F550...
10x16.5 Tire Assembly (A53472)
10x16.5 Tire...
2015 Crane Carrier Co. Low Entry T/A New Way Side Loader Garbage Truck (A51692)
2015 Crane Carrier...
2019 Ford F-450 4x4 Utility Truck, VIN # 1FT8W4DT8KEF27612 (A51572)
2019 Ford F-450...
2020 COLOMBO TM LOT NUMBER 215 (A53084)
2020 COLOMBO TM...
2 Disc Heavy Duty Bottom Plow (A51573)
2 Disc Heavy Duty...
