WoodChuckDad
Elite Member
- Joined
- Jul 15, 2015
- Messages
- 2,905
- Location
- Free Union, VA
- Tractor
- Kioti RX7320 Power Shuttle Cab, Komatsu PC130-6
WoodChuckDad:
Is the orientation of the house as showed in your plan (glazing to the North ?) If so, that would definitely contribute to a significant loss in energy efficiency... If the main glazing faces south, you would get solar gain and with a heavy concrete slab would be perfectly set up for passive solar.
I personally suggest you beware of Hearthstone. Make a very careful comparison between the way a Hearthstone and a Woodstock soapstone stove is built and its operating principle. A few hints: Hearthstone has single wall soapstone and their stoves work by the secondary air principle. Woodstock stoves are double wall soapstone and for the most part are catalytic. The combination of catalytic burn and double wall makes the woodstock stoves very easy to control for heat output and low stress. Anyone who knows how compromised the secondary air stove design is, when combined with how the emissions test is done for the EPA the stoves have a tendency to run away on a full load of fuel and be very difficult to control. When combined with 1 layer of soapstove, that frequently causes cracked stones and other air leaks, making the stove run away even more.
Most complaints I have heard about were not compensated for their damaged Hearthstone stoves since the factory regards overfiring as the fault of the owner, not inherent in the design and the nature of what one gets with a tall chimney that produces good draft under cold conditions.
I have had several secondary air type stoves and all have had the same runaway issues, its just that good quality steel stoves (NC or Pacific Energy) or good quality cast iron (Morso) survive overheating better than soapstone, especially single wall.
If you don't want a catalytic stove, look at the Pacific Energy T6 stove. It has a large firebox, the steel core of the stove is of high quality and the cast iron jacket promotes convective cooling of the stove which in turn makes a big convective plume of hot air in the house. I have a T5 which is the smaller model and it heats the upper 1300 sq ft of my home here in MI through the last few polar vortexes with -30F....
I have an Appalachian stove now. Catalytic. It's over 20 years old. I am leaning away from catalytic. The main room and front door face south, southwest The reason for facing that direction is the view of the mountains.
There is no central air system, we will be using ductless AC systems
