   / Harbor Freight Tools that don't suck #6,041
Really pleased with my Titan SSQA forks. They fit very well on both tractors. I bought the Titan extensions too.
   / Harbor Freight Tools that don't suck #6,042
   / Harbor Freight Tools that don't suck #6,044
Hey, we drive down there for Bailey's and Richard's, you can drive up here for Harbor Freight. :laughing:
Oh, I drive up there for HF when its heavy, otherwise the $6.99 flat shipping works better for cheaper ;)
   / Harbor Freight Tools that don't suck #6,045
I like the Goldblatt's shopping carts at Richards... :thumbsup:
   / Harbor Freight Tools that don't suck #6,046
Now ......... Back to regular programming.
I've been looking at the Harbor Freight hydraulic hole punch set and their 10 ton hydraulic equipment kit.
Hydraulic Punch Driver w/ 5 Hydraulic Punches & Dies
1 ton Super Heavy Duty Portable Hydraulic Equipment Kit
Anyone have experience with either?
I have the 10 ton portable hydraulic kit. Haven't used it a lot but it does what it claims to do. It requires purchasing at least one pull ram which isn't too expensive and often on sale if you want to draw things together. It comes with fittings to push things apart. Glad I have it but have used it only half a dozen times, mostly to unbend things on implements. The power of hydraulics is amazing even if man powered. I got mine used off CL.
   / Harbor Freight Tools that don't suck #6,047
The punch kit is great when used with a decent porta power. I have no idea what porta power I have, it is old and came on a pallet with some vices and other odds and end on a lot purchase at an auction. Won the lot with a bid of 103$ hoping I could make a decent vice out of the three that were in the lot. All vices were good, porta power kit has held up as well but I do not use it much.
Thanks for reminding me of this. After my 12 step group for garage sale and auction addiction failed I pretended they did not exist.... till now....
;D
   / Harbor Freight Tools that don't suck #6,048
;D
So, are you indicating that the included hydraulic pump does not work well?
   / Harbor Freight Tools that don't suck #6,049
Thanks Island!
   / Harbor Freight Tools that don't suck #6,050
Correct, it works but not seriously. A bit weak and if you bear down on it it will leak. I took it back and swapped out, the next one did the same thing. We looking for a better quality kit and did not like the prices so figured it was a deal and used it with my porta power. Not saying that everyone of them will be that way but mine was. I was using it at it's max specific limits. Cutting holes in 1/8". I have used it on thinner but that was after I started using a different pump.
2003 FORD F150 HARLEY DAVIDSON TRUCK (A58018)
2003 FORD F150...
2003 Big Tex 10PI...
2019 DRAGON ESP 150BBL ALUMINUM (A58214)
2019 DRAGON ESP...
THREE POINT MAINTAINER BLADE (A58214)
THREE POINT...
2004 FREIGHTLINER CST120 TANDEM AXLE SLEEPER TRUCK (A58018)
2004 FREIGHTLINER...
1996 Freightliner FLD112SD T/A Dump Truck (A55852)
1996 Freightliner...
