There will be an opportunity for passive solar in the main room. But there is twice as much square footage on either side of that room that will not get much sun exposure inside, due to design. The solar gain should make the heating system more efficient, but it won't be enough to heat the whole house. As for the crawlspace....I hate them. I'd much rather have the slab built and pay a bit more up front.
I hate crawl spaces as well and our house has a concrete colored slab even though the house is built on a slope. The interior of the foundation was filled with 67 stone after the waste pipes were installed. The 67 stove self compacts to 95% or some such and we have not had any settling of the slab. The slab is a colored concrete which is our finished floor. The slab does hold the heat from the stove and sun. Flip side is that if we let the house get hot in the summer or cold in the winter it takes longer and more energy to get the house temperature where we want it. Trick is to not let the slab temperature get out of whack for the season.
We though about putting in heating in the floor but for our climate it did not make money sense. Further north, I think it would make a great deal of sense to put in the floor heating.
We do have passive solar on the house which warms up the slab and it works. The roof eaves are sized so that winter sun light and enter the house but during other seasons the sun cannot enter the house. Simple, cheap and effective. While we have six inch thick walls with 1" foam on the exterior, we poke big holes in the walls for windows and doors.
We love the view but we are likely a bit cooler in the winter as a result...
We try to heat primarily with wood using a stove that is for 1800 square feet in a 2400ish square foot house. Square feet is really not a good measure though, volume should be used instead. We have 10 foot ceilings so our volume is a bit higher than a house with 8 foot ceilings. Our house has a fairly open plan and the stop is roughly in the center of the house and we have found that the hot air from the stove naturally moves around the house. This mostly works for us but when we have below normal colder days, the wood stove does not keep the house as warm as the wifey and kids would like. Meaning the stove might keep the living room in the mid to upper 70s and not 82. The far side of the house will be 5-10 degrees cooler depending on outside temperature and if the kids keep their doors closed.
We have always talked about adding a second stove for these really cold days but the reality is that this only happens for a few days a year and an extra stove is not worth the cost and space.
There is a six inch PVC pipe that runs under the slab from an exterior wall to behind the hearth. The pipe brings in combustion air for the stove and it works really well. If the fire is not running I don't feel any air moving from the pipe but if the stove has a fire you can feel the air being pulled into the house. We don't feel the cold air because it is in back of the stove and either used by the fire or heated before getting further into the room.
Later,
Dan
