Looking for Mahindra 1816 electrical diagram
   / Looking for Mahindra 1816 electrical diagram #1
graculus
Mahindra
Anyone have an electrical diagram for the 1816 starter circuit? I need to troubleshoot my starter which doesn't even try. I suspect it's the clutch switch which has needed a good kick in the past but would like a schematic of the starting circuit before I dig into it.
   / Looking for Mahindra 1816 electrical diagram #2
I have wiring diagrams in my owners manual for my 6520. The manuel came with the tractor. Did you get an owners manual when you bought your 1816?
hugs, Brandi
hugs, Brandi
Have the manual, has electrical section, but no wiring diagrams :(
   / Looking for Mahindra 1816 electrical diagram #4
I got the service manual for my 1538 and oddly enough it had wiring diagrams for the cab and such but nothing for the engine. Mahinda service documentation leaves much to be desired. It's about the worst I've ever seen that was passed off as a service manual. Not one part number in it even for the common service items like the filters. In a word, PATHETIC!
   / Looking for Mahindra 1816 electrical diagram #5
This is a sectional screenshot of a 2216's schematic for the start circuit. Pretty simple and perhaps the 1816 is close, but you mention a "clutch switch" mine doesn't have. Mine is the "gear" model, not HST. Not sure if there's difference in the electrics.
Thanks, that's a start. I imagine it's a similar solenoid/starter unit at least. Mine is HST, I know for sure it has a clutch switch, I read on another forum that there's another switch on the PTO control, and I don't know if there is also one on the Low/High range control.
   / Looking for Mahindra 1816 electrical diagram #7
Then I would guess you would say that about Boeing's Maintenance manuals or any aircraft mfg, also. Airliners all have separate maintenance manuals and parts manuals. They also have separate wiring manuals. So it doesn't bother me that Mahindra is stingy with part numbers in service manuals. Search online and you can find part numbers for Mahindra tractors. Mahindra, like aircraft mfg..........from time to time.........update manuals and change part numbers. Why incur costs of having to update service manuals also. My 6520's filter part numbers have changed since I bought the tractor in 2007.
hugs, Brandi
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A51039)
80in HD Tooth...
MAHINDRA 2816 TRACTOR (A51243)
MAHINDRA 2816...
2012 MACK PINNACLE (INOPERABLE) (A50854)
2012 MACK PINNACLE...
Westendorf Gravity Wagon (A50514)
Westendorf Gravity...
2015 Freightliner Ambulance (A50323)
2015 Freightliner...
2003 International 4300 Flatbed Truck w/ Liftgate - Inoperable - 7.6L DT466 Diesel Engine (A51039)
2003 International...
