Max 28 starts but won't stay running
   / Max 28 starts but won't stay running #11
FYI there is a specific installation procedure if you are going to install the new solenoid yourself. :alert:
Got the new solenoid under warranty, installed it and the tractor seems to be running fine now. Cleared about an acre with the bush hog and no problems with the engine cutting out. Getting the thing installed was a real pain in the posterior though. The threaded hole it goes into does not have tapered threads but is flush with the surface of the block. That, along with the tight space, makes it hard to get the solenoid positioned properly to get the threads started. Even getting the plugs connected together with my fat fingers was hard due to the wiring harness being just long enough to allow them to connect. Even another inch would have made plugging them back together much easier, especially when slick with dielectric grease. And I was lucky I was able to start the tractor and raise the loader before I removed the bad one. I hate to think of putting the cursed thing on with the loader arms down and in the way. Anyhow, everything seems good now. Thanks for everyone's assistance in helping me solve my problem.
   / Max 28 starts but won't stay running #14
Greetings Gentleman,
I was just curious; do any of you know if this solenoid issue has been (or was) resolved with later Max 28's or the newer Max 26 machines? Thanks for any info.
   / Max 28 starts but won't stay running #15
2008 Ford F-750 Crew Cab Pro Patch TCM-425-135 Asphalt Patcher Truck (A51692)
2008 Ford F-750...
(2) Tires (A50121)
(2) Tires (A50121)
Massimo MB100 Mini Bike (A50121)
Massimo MB100 Mini...
2852 (A51691)
2852 (A51691)
2018 FORREST RIVER CRUISE LITE CAMPER (A52472)
2018 FORREST RIVER...
2014 CATERPILLAR CT660S SBA 6X4 DUMP TRUCK (A51406)
2014 CATERPILLAR...
