sawduster2
I was brush cutting this morning for 2 hours, all was normal and tractor ran well and all gauges were in the normal range. Air temperature was around 80 degrees when I stopped for a drink of water and returned to tractor about 30 minutes later. Tractor wouldn't turn over and further checking showed that no electrical was working, no lights, horn, turn signals, no 4 way flasher etc. I checked PTO & trans range 4 times to make sure a safety switch wasn't open. I pulled and checked all fuses on dash panel & all were fine. I looked under the hood for a relay or fuse and couldn't locate any. I checked behind the dash and see if any hidden relays were and found what looks like a relay but I believe it is the Beru warming timer relay (0201010077). The electrical schematic shows a "maxi fuse" between the alternator & starter but I traced the wiring and see no fuse. I cleaned the battery terminals, no improvement. I left the tractor in the field and removed the battery and took it to an auto store where it tested fine (12.86 v & 1032 CCA). With no electrical device working I believe I have a blown fuse or relay somewhere. Any suggestions where to look? I do not have a "fan" switch on the dash as was mentioned in a previous post.
Any suggestions are greatly appreciated.
I've added photos of left & right side of motor.
