35 Hours Seat Time - Kubota M7060
   / 35 Hours Seat Time - Kubota M7060 #1
JeffroL
Sperryville
Deutz D4006; Kubota M7060; John Deere 500C
I thought I would post my impression after my tough Kubota vs. Mahindra vs. John Deere decision outlined here: http://www.tractorbynet.com/forums/...isons/367154-my-journey-mahindra-vs-john.html. I chose to go with a used Kubota M7060 and thought I would share my inexperienced impressions for anyone shopping similar tractors and might want some raw feedback on the Kubota M7060 (and presumably similar models).
What I Like - My old tractor is extremely basic so my basis for comparison is 40 years old. That said, I LOVE the slider throttle on the Kubota, conveniently located with right hand access. It's just super convenient. The tractor drives and handles extremely well and the 4WD is a tremendous upgrade over my older tractor (a 1975ish Deutz D4006). The lift is powerful and easy to operate BUT get careful if you aren't experienced, things get "tippy" when you hoist a heavy load. Go slow. The tractor has plenty of power and is generally just very comfortable to operate. I also like the compatibility of the FEL with attachments. I have a quick-attach implement (Danuser Intimidator) and no adapters, etc. are necessary. I don't feel brand locked. The shuttle transmission is also fantastic. No more do I feel like I'm "rowing" through the work with my gear shifter!
What I Don't Like - I'm particular and again, not experienced, so take this with a grain of salt. The shuttle transmission lever while GREAT is very very easy to move. There isn't a terribly distinctive "stop point" when it hits neutral vs. reverse vs. forward. A couple of times I've gone to pull it from reverse into the neutral and then to forward, and gone straight to forward. Ooops. That's abrupt, and can't be great for the transmission. My M7060 is not equipped with a "creep" option - I would absolutely get that option if I were buying a new tractor. In 1st gear running at a good engine speed, it's just a little too fast for really delicate work and maneuvers. That might be my inexperience showing, but I'd prefer to go slower without having to nearly idle the engine. The transmission lock on my tractor is very sticky, it often decides that it is just not going to release. As a result I don't use it and likely will have to send it back to the dealer. It's a huge hassle, but not one I see as a brand issue, likely just this tractor. No one else seems to have every had /posted about this problem. The DPF is also an oddity. On my tractor, there is the "park and regenerate option" as well as an "auto" option where it theoretically will regenerate while you work. The latter has never worked for me. I think the light on the buttom may be out so I just can't tell it's on. But the tractor engine noise changes when I press it, but the regen light just keeps blinking and the button light doesn't light up. So I can't tell if it's working. Inevitably I just wind up parking / regenning which takes 5-10 minutes. Seems to be running about every 25 hours or so. Not a big deal but I'm not really a fan. The price of progress I guess. The engine doesn't blow smoke and my old tractor blows huge clouds. So I guess it's cleaner.
Again, I'm picky and particular. So I take note of all the things I'm not particularly fond of. But overall it's a great tractor. I particularly enjoy the Danuser Intimidator. No I'm not a dealer / rep but DANG that thing is handy. I've been pushing over problematic trees and ripping out invasive shrubs for hours and hours. It's just ridiculously fun. I'll leave you with a shot of a girdled holly tree by my pond that needed to come out. I pushed it over, picked the whole thing up, and stuffed it in the woods. So easy.
-Jeff
   / 35 Hours Seat Time - Kubota M7060 #2
Thanks for your review Jeff. Its great to get some closure on intense discussions like yours. Hearing about your dpf troubles makes me want to hang onto our pre tier 4 tractors for a long time lol. I'm sure they'll get it figured out soon. Definitely keep an eye on it though as cleaning them can be costly.
   / 35 Hours Seat Time - Kubota M7060 #3
Off topic
Depending on the size anywhere from $900 to $1500. We just went in $47,000 to be able to do our own, but we have 250+ DPFs to care for. This will be our second of this machine, the other one does north of 300 DPFs. This will also be our third machine type. The sonic ones are garbage, FSX makes the finest DPF cleaning solution available, complete with flow bench for benchmarking and testing the efficacy of the service.
When you get yours cleaned, it will eventually need it, ask about the method of cleaning. Sonic machines have a high rate of internal micro-fracturing of the media, unfortunate real life experience. If you do not think that is important price a brand-new DPF. Prices on them will come down eventually but probably not soon.
Just meant to reinforce the need to make sure your regen cycles are taken care of and you are doing what is needed to ensure the DPF is staying clean.
   / 35 Hours Seat Time - Kubota M7060 #4
Nice insight there CreekyB. I had heard from my dealer that it cost their last customer ~$1,200 so that seems right in line with what you said.
   / 35 Hours Seat Time - Kubota M7060 #5
I will edit the post, my little jaunt into off-topic was to reinforce the need to make sure you are doing what you need to do to keep the filter clean. None of them are meeting the manufacturer's spec for service before removing and cleaning or replacing. We clean ours internally now, taking special care. Just the DPF alone is a bit north of $10,000 on one of our engines. They are making it about 60% of the way to the recommended removal and cleaning point.
My experience is limited to onroad large Cummins engines.
UNUSED LANDHONOR UNIVERSAL ADAPTER PLATE (A54757)
UNUSED LANDHONOR...
Kubota SVL65-2 Open Station Rubber Block Tread Skid Steer (A55218)
Kubota SVL65-2...
2018 FREIGHTLINER 108SD DUMP TRUCK (A51406)
2018 FREIGHTLINER...
UNUSED 20 in. Gasoline Chain Saw (A53117)
UNUSED 20 in...
2012 Cadillac SRX SUV (A53424)
2012 Cadillac SRX...
2020 KENWORTH W990 TRI AXLE DUMP TRUCK (A54607)
2020 KENWORTH W990...
