2030 Hydraulic Noise
   / 2030 Hydraulic Noise #1
jhertenstein
Flora, IL
John Deere 2030
Hello all,
I have a 70's vintage 2030. I recently had to have the brake pads replaced because they were deteriorating and plugging up the hydraulic intake. Now I'm hearing a new noise that seems to be coming from the hydraulic pump. This is confirmed by actuating one of the loader valves which changes or eliminates the noise. Is the pump bad? There doesn't seem to be any loss in hydraulic power.
As a separate issue both the loader and the three point will "drift" lower even with the tractor running at a high RPM. What causes this effect?
Thanks in advance for your support.
Hertenstein
   / 2030 Hydraulic Noise #2
1st thing I suggest to check is condition of frt hyd pump drive coupler. Moving of hyd components such as 3 pt or loader while control isn't actuated could indicate leaking cyl seals or internal leaking control valve
Thanks. The control valve is pretty noise and makes a high pitched "hissing" sound which I assume is fluid leaking through.
2006 Volvo VNM Truck, VIN # 4V4M19GF26N396168 (A51572)
2006 Volvo VNM...
2016 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A51692)
2016 Peterbilt 320...
2016 Ford F-550 Palfinger PSC3216 4,000LB 2 Ton Crane Service Truck (A51692)
2016 Ford F-550...
2005 CATERPILLAR 321C LCR EXCAVATOR (A51246)
2005 CATERPILLAR...
2016 Toro Groundsmaster 3505D 72in Rotary Mower (A51691)
2016 Toro...
2005 Chevrolet Colorado 4x4 Pickup Truck (A51692)
2005 Chevrolet...
