Hyd cylinder parts
   / Hyd cylinder parts #1
handirifle
Central Coast of CA
Massey Ferguson 1010
On my splitter, the end plate, the one the piston goes through, has developed a leak. It started with a pin hole in the top section, that leaked occasionally, but now it seems to leak constantly when in use.
Can I get just the new end plate or do I have to get a whole new cylinder? I hope just the plate. I do not currently have numbers from the cylinder to reference. I think the main cyl is 5" with a 1.25" piston, but that's a guess.
It seems like all my leaks showed up at once. I also have a hose, and what looks like the shaft seal on my pump. Good grief, when it rains it pours. I am hoping to get all my splitting done before tearing it down for repairs. I am assuming the repairs will take me some time, and we have a couple long RV trips planned for the fall, and want my wood split before we travel. I have MOST of what NEEDS to be split, but there is more to do.
   / Hyd cylinder parts #2
Is it a tie rod cyl? You are calling the rod a piston. The piston would be just under the size of the barrel.
What is a tie rod piston? I'm sure it's the rod diameter that is 1.25" Cannot see the piston, I assume that is inside the cylinder.
   / Hyd cylinder parts #4
quote; What is a tie rod piston. I don't know! I said tie rod cyl. A tie rod cyl is that it has 4 long rods that hold the end caps on. The barrel and end caps have flat o rings to keep them from leaking and that might be what's wrong with yours.
OK sorry I totally blew that one. Yes it IS a tie rod cylinder. It has the long bolts. No, that is not what is leaking. There is a tiny pin hole at the top of the 1/2" thick end plate that the rod goes through. I can see fluid squirt up about 1/4" if I do not release the lever when the rod is all the way in the cylinder. At least is used to be that way. It's getting worse.
   / Hyd cylinder parts #6
Well I thought I had a place booked mark that sold the end cap and other parts for them. I looked at all the info I have and can't find it. Take it to a hyd repair shop and maybe they can fill the hole by brazing it.
Here's where it's leaking
It's (I think) a 4" bore and 1.5" rod. Measured the rod, cylinder outside dim is 4.5".
   / Hyd cylinder parts #8
For some reason my phone won't load your picture but depending where it is leaking I would look into maybe drilling the hole out to say 1/8 and down 3/16 or 1/4 inch then hit it with the mig welder. I say mig because I "THINK" (someone who knows correct me if I wrong) it would be faster and allow less heat into the end cap than brazing and possibly damage the seal.
That's exactly what I was wondering about doing. I HOPE that will fix it cause a new cylinder is pricey.
   / Hyd cylinder parts #10
Brazing it would have to come apart, that's not hard at all. The end caps are cast iron. I was thinking with brazing that you might be able to fill the hole all the way up.
Under Body Toolbox (A51573)
Under Body Toolbox...
3 1/2 FT DISC HARROW (A51247)
3 1/2 FT DISC...
WESSEX CRX 240 LOT NUMBER 169 (A53084)
WESSEX CRX 240 LOT...
2021 Club Car Carryall 500 Utility Cart (A51691)
2021 Club Car...
2013 INTERNATIONAL WORKSTAR 7600 SBA 6X4 DUMP TRK (A51406)
2013 INTERNATIONAL...
