Winter Is Coming,,, Do I Need A Clutch Block?
   / Winter Is Coming,,, Do I Need A Clutch Block? #1
CADplans
Elite Member
near Roanoke VA
584 IH 4WD
My JD 650 will set most of the winter,,, well,,, except for some "sport riding" in the snow,,,
A previous tractor I owned some decades ago had a lever to block the clutch disengaged,,,
so the clutch would not "stick" because the clutch disk could rust to the flywheel.
Do I need to consider adding this to the 650? Does anyone have pics of a possible clutch block?
Thanks for looking!! :thumbsup:
   / Winter Is Coming,,, Do I Need A Clutch Block? #2
Yes, do it. Stick a block of wood in the pedal linkage to hold it down a bit.
   / Winter Is Coming,,, Do I Need A Clutch Block? #3
Or a bungee cord to tie it should work too.. But many thanks for the awesome winter pic. I can hardly wait for that weather to come back around. :thumbsup:
No skeeters, no bugs, no heat, no humidity .. and snow to push around.
   / Winter Is Coming,,, Do I Need A Clutch Block? #4
Too sad to let it sit most of the winter! Should be out pushing snow. Is it stored in or out?
I have plenty of room to store it inside,,,
I was planning on using it to move snow, but, last winter dictated a need for more machine,,
The 650 would have trouble with this,,,
   / Winter Is Coming,,, Do I Need A Clutch Block? #6
What does your owner's manual have to say?
The manual for my Kubota says to use a clutch block when the tractor is not used for an "extended period," but doesn't specify what constitutes an "extended period." The tractor came with a small block with a dado on one sdie for that purpose.
The manual for my NH is silent on the matter.
Steve
   / Winter Is Coming,,, Do I Need A Clutch Block? #7
Steve
I have looked for it in the manual,, but, the epistle is about 800 pages long,,
so I have not found it,,,:confused2:
Then why block the clutch? ... Because its something to do?
My Mitsubishi MT-372 had the clutch stick setting in a similar shed,,,
I think the clutch will stick with very little moisture present,,,
   / Winter Is Coming,,, Do I Need A Clutch Block? #10
800 pages -- Wow!
I would look under "Extended Storage" or something similar.
Steve
2014 INTERNATIONAL PROSTAR (A58214)
2014 INTERNATIONAL...
excavator trenching bucket- one bucket per lot (A56435)
excavator...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2013 PETERBILT 367 DAYCAB (A58214)
2013 PETERBILT 367...
2017 Ford Escape AWD SUV (A55758)
2017 Ford Escape...
