New owner here
   / New owner here #1
Yardcut
Butler, PA
Husqvarna YTH24v48
I purchased this model from a local dealer for $1995 plus tax. Delivery was free. It came delivered setup and ready to go, even with a full tank of gas. I have used it twice and the following review is based on relatively new experience with Husqvarna products.
PROS
*Very nimble considering the heft of the machine
*Cuts evenly (but discharge chute is a pain)
*Plenty of power
*Greasable deck spindles
*B&S USA assembled engine
*Tuff Torq K57 transaxle, a step above the ubiquitous k46 found on lesser units.
*blades have high lift and can toss the grass IF you move the plastic shield from the discharge chute
*10 year warranty on the deck shell only, 3 year on the rest of the unit, 2 years on B&S engine
*Can turn the key back on click from run and the ROS remains engaged so you can mow in reverse.
*K57 Hydrostat is responsive and smooth.
CONS
*Fuel gauge is very hard to see
*Deck does not pivot with front axle
*B&S Engine at 24HP is way overkill for a basic rider like this
*Have to remove to plastic side fences to get at oil filter, fuel filter, and oil drain port
My primary goal is as follows. All I need is a mower to cut grass. Not to mulch. Not to bag. Just cut. Thus far, this unit does fairly well but still falls short of the 1990's era Ariens YT1340 unit my dad had back in Indiana.
Nevertheless, after a lot of research I decided on this unit. It is the last of the units that Husky will offer with a K57 transaxle. Going forward, all the units, yes even the ones sold at Lowes, will have a plastic, yes you read that right, plastic CVT made by General Transmission.
The mower starts and runs well. The B&S engine has an automatic choke that makes starting a breeze. Once you get in position, you lower the deck to desired height, rev up to full throttle, engage the electric PTO and off you go. The mower handles my grass with ease; I cannot comment on high thick stuff as I live in a residential area and keep my grass cut so it looks neat. I would assume with 24 ponies under the hood, it should handle the task.
The deck appears to be robust and with the 10 year warranty on the shell, I think it should last a while. The only drawback I see is it does not pivot with the front axle so evenness of cut is lacking compared to others that offer this design feature. The reverse speed is sufficient so as not to slow things down, it can really get up and go when you mash the pedal but I don't consider that a priority when mowing.
The B&S engine is OHV with full pressure lubrication, cast iron sleeves, and oil filter. Seems ok but at 24 HP I question, seriously, is all that HP necessary when I mowed for years with 12-15 HP machines as a kid. Still it runs well and has not used any oil during break in. Parts are easy to come by also.
The battery is a basic 240 CCA 12V affair that you can buy anywhere. Blades are available at Lowes. I plan on having the dealer perform all the service save for oil changes.
I cannot comment on removing the deck as I see no need to do so. LIke I said, this needs to cut grass. No more, no less. I cannot comment on pulling power as I have no cart or dethatcher but again, with 24 ponies under the hood, I cannot see it being underpowered. If anything, the K57 transaxle will give up the ghost long before the engine will under such usage.
Overall, it is a good unit. Time will tell how reliable it is. JD missed the mark by not having greaseable spindles and requires you to hold in a flimsy yellow plastic button to mow in reverse. Otherwise I would have purchased a JD. In the end, it came down to details.
   / New owner here #2
G'day Mate and welcome to TBN from Downunder.
Ta for your review. I believe that you'll find that quite a few other colour tractor OEMs utilise a RIO button... and an Operator In Seat safety switch. Pretty much industry standard now and, although I don't recommend it, there are simple alterations you can make to 'cheat' these safety devices. JD did not "miss the mark".
Enjoy the site.
   / New owner here
It did clog on me last week when I mowed slightly wet grass. I do mean slightly wet. Kinda disappointing with 24 horses under the bonnet and it still bogged like that. Blades are sharp so that was not the issue. I did cut off about 4 inches of the dumb deflector that really kills the dispersal of the cut grass.
   / New owner here
   / New owner here #6
I recently got the sister to yours (a YTA24V48) and it does not like wet grass either. She would power thru the tall areas, but I had to slow her down to a crawl or she would begin to bog down, but the transmission really rather go fast. You could tell the 24 horses would strain a little in the tall wet grass. But heck, I had an old 8N Ford tractor that had about the same number of horses and she had a lot more power that the little mower does I think. There were a couple times I could tell the grass bound up in a clump under the deck and dropped down into the spinning blades to be chopped out the side suddenly like I had hit a stick. One thing I noticed the first time I engaged the blades is that sucker sounds like an airplane when they spin. I never looked for the RPMs, but they sure seem to have some speed to them. It will mow dry grass at a pretty good clip though.
   / New owner here
I wonder just how close the HP rating is to 24HP{? Mowed with a 13 HP Ariens back in the day and I know it had a lot more power than this one does. Youj're right the grass clumps sound like you are hitting rocks or something.
   / New owner here #8
Excellent write-up Yardcut! Very through.
I too, wonder about the horsepower ratings on mowers these days. I have a 26hp GTH Husqvarna... Even with the "26hp" I don't think it has any more actual power than my old Snapper 8hp. Of course, the Husqvarna is cutting a 52" swath whereas the Snapper was cutting a 30"; big difference. (I think the manufacturers are playing games with the horsepower propaganda.)
Even so, with 26hp, wet grass is a pretty much a no-no. It not only clogs up, but it doesn't cut evenly either. ...just a waste of time.
I did make another (non-related) discovery last week though. I needed to swap out my blades but only had 1 mulching blade and 2 high-lift blades. Those two styles do not go well together. My lawn looked like a baseball field with the different cut heights and pattern :) Obviously, I switched the high-lift blades out yesterday and recut the lawn. Lesson learned: Keep the blades properly matched.
Oh - as another non-related item, I think the mulching kit Husqvarna has available for their big mower/tractors suck.
Again - thanks for the great write-up!
   / New owner here
Might be CPSC or EPA regs haunting us here. At any rate, I did expect more oooomph from such a large engine.
   / New owner here
Good news is once I cut back the darn plastic deflector, it throws grass much better now. Doesn't bog down as much.
PALLET OF (14) CAT WALK STEPS (A53843)
PALLET OF (14) CAT...
2012 DRAGON PRODUCTS 130BBL VACUUM TRAILER (A53843)
2012 DRAGON...
2007 Reitnouer 40 Ton T/A Heavy Haul Flatbed Trailer (A52377)
2007 Reitnouer 40...
2025 K0311 UNUSED Galvalume Corrugated Steel Panel (A53117)
2025 K0311 UNUSED...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
VERMEER RTX 130 WALK BEHIND TRENCHER (A51242)
VERMEER RTX 130...
