PSI/RPM curve for BX 25
   / PSI/RPM curve for BX 25 #11
What about the curve? What pressures in between?
   / PSI/RPM curve for BX 25 #12
My MX4800 is the same way. Always makes me chuckle when someone regurgitates the TBN dogma that RPMs don't dictate hydraulic force.
   / PSI/RPM curve for BX 25 #13
There are a couple of things at play here, pressure and volume. I'm not sure but at idle even if the pressure is enough to run the hydraulics, my guess is the volume isn't enough. I know on my BX the hydraulics prettty much won't do anything unless you bring the engine up off idle to maybe 1800 rpms. Of course this thread is 6 years old also, but still relevant.
   / PSI/RPM curve for BX 25 #14
Here is the data points for my MX.
And a few hundred PSI make a much bigger real-world difference than one might think....
   / PSI/RPM curve for BX 25 #15
For the first 1/4 to 1/3 throttle ALL hydraulic flow goes to power steering and charge pump circuit with barely any flow going to loader and then 3 point hitch.
Once you get flow above the flow required by the power steering you will start to see movement on the loader and 3 point hitch.
David
   / PSI/RPM curve for BX 25 #16
David
That is not the case with either of the kubota's with loaders I have owned. :confused3: maybe I'm misunderstanding.
   / PSI/RPM curve for BX 25 #17
Our tractors have separate pumps for the steering.
   / PSI/RPM curve for BX 25 #18
Yes you are misunderstanding, my L3130 has a 2 section pump. First section is power steering and GST transmission supply, second section is implement/ loader.
Some of the larger Kubota TLBs have a third section for the backhoe swing.
David
   / PSI/RPM curve for BX 25 #20
Lifting something to heavy and my loader will go into relief at idle, increasing RPM's makes little to no difference in lift power.
2014 PETERBILT 388 AUTO TRANSPORTER (A52576)
2014 PETERBILT 388...
2013 International DuraStar 4400 Altec AM547 50FT Material Handling Insulated Forestry Bucket Truck (A51692)
2013 International...
EZ-GO Textron Electric Golf Cart (A51694)
EZ-GO Textron...
2008 FORD RANGER SINGLE CAB TRUCK (A51406)
2008 FORD RANGER...
(4) 55 Gallon Drums of Mixed Laundry Detergent and Fabric Softener (A51573)
(4) 55 Gallon...
KUHN SR110 GII LOT NUMBER 39 (A53084)
KUHN SR110 GII LOT...
