Skidding a Log Over Wet Area
   / Skidding a Log Over Wet Area #21
Measure your cut lengths off in shorter sections that you can move easier, more trips involved, cleaner wood, personally, i wouldn't be deterred by a little dirt.
Ronnie
   / Skidding a Log Over Wet Area #22
I lift the "big" end with the 3 point and let the last little bit of small end ride on the ground...
SR
   / Skidding a Log Over Wet Area #23
Lol don't they get dirt on them when they fall? If you have a loader just cutter small enough to fit in the bucket
   / Skidding a Log Over Wet Area #24
How big of an oak log are you talkin'?
The internet says (so it must be true) that Oak has a density of around 45 lb/ cu. ft.
A 2' diameter log is going to weigh about 141 lbs/ linear ft.
A 20' log of this diameter will weigh about 2800 lbs. ( -so make sure you use 3/4" plywood vs 3/8" when you make your bogie wheels. :D)
Your calculations may be a bit off.
Per the woodweb calculator the estimated weight would be 4,119 lbs.
/edit thats fo green wood
   / Skidding a Log Over Wet Area #25
Sometimes... but not always.
Many times I lay cross pieces (limbs) to drop them on, and it keeps them off the ground. It just depends on what tree and what kind of log is in it.
SR
   / Skidding a Log Over Wet Area #26
Not unless they are falling in mud holes. I don't like working in mud holes so that's usually a non existent problem.
   / Skidding a Log Over Wet Area #27
fall tree... attach tractor at base of tree... leave all branches on.... Lift tractor end.... drag out tree.... once in the location you want... cut all the branches off.
with any luck the trunk of the tree will barely touch the ground.
   / Skidding a Log Over Wet Area #28
Uhhhhh...... and have a massive pile of slash on my landing where I'm trying to cut? No thanks! Maybe if I have my chipper parked right there.
SET OF (3) ALCOA 24.5 ALUMINUM RIMS (A53843)
SET OF (3) ALCOA...
2011 CIRCLE M 32 FOOT GOOSENECK (A53843)
2011 CIRCLE M 32...
TURBO SAW SKID STEER ATTACHMENT (A53843)
TURBO SAW SKID...
2004 Chevrolet Silverado 2500HD Service Truck (A53422)
2004 Chevrolet...
2008 VOLVO EC460CL (A52472)
2008 VOLVO EC460CL...
2016 JOHN DEERE 3032E LOT NUMBER 94 (A53084)
2016 JOHN DEERE...
