boot for hydraylic lift MF 35
   / boot for hydraylic lift MF 35 #1
Farmer Scott
Moncton, New Brunswick
Massey Ferguson 35
What is involved in replacing the boot for the hydraulic lift top link as shown in the photo below as part #7
Is there a simple way to do it or do I have to remove the lift cover?
Any input is greatly appreciated
Thanks
Scott
   / boot for hydraylic lift MF 35 #2
Thanks
Scott
the difficulty is that the yoke nut, which is threaded on the plunger is usually difficult to remove UNLESS someone put anti seize on it when they assembled it. You may have to disconnect something in the three point hydraulic control system before you try to unscrew it. Get a shop manual to see what they recommend.
   / boot for hydraylic lift MF 35 #3
Unscrew part 6 and the whole thing comes out, usually part 3 and 8 are rusted together and the parts are so cheap that I just buy them new, do not buy cheap rubber parts, go to the dealer and buy a original part, many of the cheap ones are junk after a year in the sun.
And remember to loosen set screw 17, part 6 is almost always in a bad shape after removal if you dont have the special tool to unscrew it with.
2001 CATERPILLAR 140H VHP MOTORGRADER (A51406)
2001 CATERPILLAR...
2018 Ford Fusion Hybrid Sedan (A53424)
2018 Ford Fusion...
2008 KOMATSU PC200LC-8 EXCAVATOR (A52706)
2008 KOMATSU...
2025 K732 UNUSED Flower Bed (A53117)
2025 K732 UNUSED...
6 pallets Miscellaneous PPE equipment (A53117)
6 pallets...
2000 Mercedes-Benz S-Class Sedan (A53424)
2000 Mercedes-Benz...
