dfkrug
Super Member
- Joined
- Feb 3, 2004
- Messages
- 7,654
- Location
- Santa Cruz Mtns, CA
- Tractor
- 05 Kioti CK30HST w/ Prairie Dog backhoe, XN08 mini-X
BRETTSKI:
I assume you have verified clean fluid as suggested above. It is also important to make sure the inlet to
the pump is not obstructed, causing cavitation. Sometimes these PTO pump systems use an inlet
screen inside the tank on the inlet of the IN hose. You should also make sure the vent in the cap is
not blocked and the fluid is not contaminated.
I am certain you have a trochoid (gear) pump that looks something like this photo. If it is Chinese,
it also may have poor assembly and internal leaks due to improper seal installation.
