3 point hitch round bale spear jammed in hitch
   / 3 point hitch round bale spear jammed in hitch #1
nhinze
Kubota BX 2200
My 3 point hitch round bale spear is jammed in one of the lower arms of the 3 point hitch. That side is a bit bent and won't come out. I hammered the crap out of it and it won't budge. I tried spraying with WD40. It just won't go in or out of the hole. Any good ideas?
   / 3 point hitch round bale spear jammed in hitch #2
can you reach the bolt on the holding the pin to the spear? Maybe try to remove the bold then spread the 3 pt arms OR maybe giving the pin some play will allow it to come free
Holding pin is welded to the 3 point spear. I got the other arm and top link off no problem.
   / 3 point hitch round bale spear jammed in hitch #4
Detach the lower link from the tractor to give you more play?
Steve
   / 3 point hitch round bale spear jammed in hitch #5
A Portaband, and a new pin will fix the issue.
   / 3 point hitch round bale spear jammed in hitch #6
bigger hammer
   / 3 point hitch round bale spear jammed in hitch #7
WD40 is a crap lubricant. It stands for Water Displacement formula # 40, which you can identify as being designed for lubricant. Try a real penitrating oil for better results. Although with bent stuff, the best lube around might not be nearly enough.
   / 3 point hitch round bale spear jammed in hitch #8
Steve
Agree with Steve. Seeing as you've been able to remove the other two points and cannot release the bent/jammed point, you'll need to remove it with the entire arm/link on that side. It'll give you more visibility of the problem and move leverage to correct the 'jam'.
A lanolin based lubricant (Fluid Film?) may help.
   / 3 point hitch round bale spear jammed in hitch #9
Steve
I agree as this allows a lot more room to work around it. If the pin is bent and won't allow the lower link to come off then cut the pin apart and replace with a new one.
I would not try to save this bent pin as it will continue to make attaching to this implement a pita.
   / 3 point hitch round bale spear jammed in hitch #10
With the lower arm off you may be able to use a gear puller.
BTW best penetrating lube I have used is a 50/50 mix of ATF and acetone.
2008 Nissan Sentra Sedan (A51694)
2008 Nissan Sentra...
2013 COACHMEN CATALINA TRAVEL TRAILER (A52472)
2013 COACHMEN...
2009 Ford F-550 4x4 11ft Flatbed Truck (A50323)
2009 Ford F-550...
377811 (A48836)
377811 (A48836)
2014 Dynapac CC4200 Tandem Vibratory Roller (A52748)
2014 Dynapac...
JOHN DEERE 3040 TRACTOR (A50459)
JOHN DEERE 3040...
