3 point hitch round bale spear jammed in hitch
   / 3 point hitch round bale spear jammed in hitch #1
nhinze
Kubota BX 2200
My 3 point hitch round bale spear is jammed in one of the lower arms of the 3 point hitch. That side is a bit bent and won't come out. I hammered the crap out of it and it won't budge. I tried spraying with WD40. It just won't go in or out of the hole. Any good ideas?
   / 3 point hitch round bale spear jammed in hitch #2
can you reach the bolt on the holding the pin to the spear? Maybe try to remove the bold then spread the 3 pt arms OR maybe giving the pin some play will allow it to come free
Holding pin is welded to the 3 point spear. I got the other arm and top link off no problem.
   / 3 point hitch round bale spear jammed in hitch #4
Detach the lower link from the tractor to give you more play?
Steve
   / 3 point hitch round bale spear jammed in hitch #5
A Portaband, and a new pin will fix the issue.
   / 3 point hitch round bale spear jammed in hitch #6
bigger hammer
   / 3 point hitch round bale spear jammed in hitch #7
WD40 is a crap lubricant. It stands for Water Displacement formula # 40, which you can identify as being designed for lubricant. Try a real penitrating oil for better results. Although with bent stuff, the best lube around might not be nearly enough.
   / 3 point hitch round bale spear jammed in hitch #8
Steve
Agree with Steve. Seeing as you've been able to remove the other two points and cannot release the bent/jammed point, you'll need to remove it with the entire arm/link on that side. It'll give you more visibility of the problem and move leverage to correct the 'jam'.
A lanolin based lubricant (Fluid Film?) may help.
   / 3 point hitch round bale spear jammed in hitch #9
Steve
I agree as this allows a lot more room to work around it. If the pin is bent and won't allow the lower link to come off then cut the pin apart and replace with a new one.
I would not try to save this bent pin as it will continue to make attaching to this implement a pita.
   / 3 point hitch round bale spear jammed in hitch #10
With the lower arm off you may be able to use a gear puller.
BTW best penetrating lube I have used is a 50/50 mix of ATF and acetone.
2017 Peterbilt 567 Day Cab (A52384)
2017 Peterbilt 567...
Bobcat 14" Hydraulic Asphalt Plainer (A52384)
Bobcat 14"...
197711 (A51244)
197711 (A51244)
2015 DODGE RAM 1500 CREW CAB TRUCK (A51406)
2015 DODGE RAM...
2019 ExMark Lazer Z S-Series 72in Zero Turn Mower (A51691)
2019 ExMark Lazer...
2022 CATERPILLAR 980 WHEEL LOADER (A51246)
2022 CATERPILLAR...
