2555 INPUT SEAL/ BEARING FAILURE gear trans
   / 2555 INPUT SEAL/ BEARING FAILURE gear trans #1
melroebobcat
USA
BOBCAT
Had a outer bearing failure on 2555, shaft bearing and other components have to be replaced pictures attached. anyone heard of this happening at 75 hours?
   / 2555 INPUT SEAL/ BEARING FAILURE gear trans #2
   / 2555 INPUT SEAL/ BEARING FAILURE gear trans #3
I agree thats way to soon for that kind of failure.Ive worked on a bunch of tractors that lived very rough lifes with very little maintainance and have not seen something like that.
   / 2555 INPUT SEAL/ BEARING FAILURE gear trans #4
Sounds like a warranty claim to me.
   / 2555 INPUT SEAL/ BEARING FAILURE gear trans #5
yep thats what a warranty is for... Even the big names have it happen occasionally. Lost a $20,000 turbo on a caseih after less than 1000 hrs. covered under warranty.
   / 2555 INPUT SEAL/ BEARING FAILURE gear trans #6
That's not many hours for that kind of a failure. I'm beginning to wonder about the TYM made stuff.
I have not seen any real problems with the TYM machines. The Mahindra ones have had EGR problems. But this problem appears to the first that I have seen.
yeah exactly, this tractor just needed the update and then as soon as I got done test driving it for 4 mins 30 seconds it gave out after tractor was shut off... it went from a drip every few seconds to complete loss of oil in between front-center case. it had no leak ... our shop foreman was about to shut it off and I insisted on test driving very briefly as usual. and it so happen to give out luckily before we returned the machine to the customer 1HR and 10Mins away. All parts + the case $1650 actual cost to Mahindra maybe $1000. 20 hour job
   / 2555 INPUT SEAL/ BEARING FAILURE gear trans #8
At least it will get taken care of before the customer has to deal with it. Unlike some poor souls. Wow 20 hours work for a 2 dollar seal. Kinda glad now that my machine was a Mitsu build.
I will say This!
Mahindra Stands behind there tractors. Never had an issue with warranty approval. The 2555 tier 4 model was a little before its time. All the kinks have been worked out. I recommend buying a HST Over Gear For sure. I will post some pictures of rebuild for those who are interested. ALso ill post picture of all parts that have to be replaced with a mid case overheat.
2012 Ford F-150 Crew Cab Pickup Truck (A50323)
2012 Ford F-150...
2020 FREIGHTLINER CASCADIA 126 TANDEM AXLE SLEEPER TRUCK (A52141)
2020 FREIGHTLINER...
General 7000 EXL 7000 Watt Generator (A50322)
General 7000 EXL...
Parker 2500 Gravity Wagon W/Auger (A50774)
Parker 2500...
2025 Swict 84in Bucket Skid Steer Attachment (A51691)
2025 Swict 84in...
2014 Nissan Maxima Sedan (A50324)
2014 Nissan Maxima...
