Planters Land Pride No Till 3p606nt
   / Land Pride No Till 3p606nt #1
koamfps
Michigan
NH TN70DA & NH 2120
More than likely purchasing one next week.
Anyone had any direct contact/used one of these? Like to hear some pros and cons. (operating use issues)
   / Land Pride No Till 3p606nt #3
We have a 606TN pull-type and have been thoroughly impressed. What are your plans for it? Any reason you are choosing the 3pt vs pull-type? The biggest advantage to the 3pt are the maneuverability and trailerability. The wheels are just a hair too wide to drive the tractor and drill on a 102" trailer. I think the pull-type better follows the contours of the ground and is more effective planting while turning (in a large radius). The 3pt's have a tendency to push dirt with the openers leaving an inconsistent planting depth and and packing.
The 3 pt 606NT after a year of use has it's ups and downs. I do get occasional bare spots. When you lift at the end of a run to turn you lose some seed. Lastly changing the depth wheel SUCKS there has to be a better way! I plant everything from Clover to SunHemp to beans and corn to small grains the depth wheel is really my only complaint oh and the cost :)
For tight spots and trailer-ing. a 3pt is the way to go.
   / Land Pride No Till 3p606nt #5
I just purchased a used 606NT, although it's the tow model, not 3-pt.
Other than the hydraulic capacity needed to hoist the 3-pt, what minimum tractor size would you say is needed for pulling the 606NT up hills, soft ground, etc? We are considering a Deere 4520 (60hp), but it only weighs a bit under 5K lbs with loader and filled rears
   / Land Pride No Till 3p606nt #6
I actually have the same question. So I guess I will revive an old thread.
The website for landpride says the 606nt needs a 40 up minimum. Has anyone tried to pull with a 40 hp tractor?
I have a jd 990 and is claimed at 40 hp with an actual of 38.5.
ATLAS XAS110 COMPRESSOR (A52472)
ATLAS XAS110...
2017 Ford Expedition EL Multipurpose Vehicle (MPV) (A51694)
2017 Ford...
2012 CATERPILLAR 279C2 SKID STEER (A51242)
2012 CATERPILLAR...
2020 CHEVROLET W4500 16FT REEFER BOX TRUCK (A52576)
2020 CHEVROLET...
23222 (A50323)
23222 (A50323)
2013 Chevrolet Caprice Sedan (A50324)
2013 Chevrolet...
