Telescoping lift arm won't stay locked in new holland 4630
   / Telescoping lift arm won't stay locked in new holland 4630 #11
Remove nut (60), slide out pin (58), raise lock (44), link end(46) should slide out, remove roll pin (42) and you should be able to remove lock, inspect for missing material, compare to new part or opposite side, I have had to replace a broken lock 3-4 times each side on my 4610
   / Telescoping lift arm won't stay locked in new holland 4630 #12
is the kit you buy difficult to install, last i checked its about a hundred dollars
Thanks
   / Telescoping lift arm won't stay locked in new holland 4630 #13
Disassemble and clean, look for rounded edges were the dog latches into the extendable link, dress up the notch in the extendable link.
2022 CASE 580 SUPER N BACKHOE (A51246)
2022 CASE 580...
JOHN DEERE TX LOT IDENTIFIER 139 (A53084)
JOHN DEERE TX LOT...
Hydraulic Coupler 80 mm Pins (A52384)
Hydraulic Coupler...
2015 Redi Haul Tilt Deck Equipment Trailer  (A52384)
2015 Redi Haul...
1982 LeeBoy Motor Grader (A53472)
1982 LeeBoy Motor...
6"x8' Treated Post,  Approx. 28 Piece Bundle  (A52384)
6"x8' Treated...
