Freeware Office suite software
   / Freeware Office suite software #11
I tried Open Office briefly probably in the 90's and found it quite similar to MS Office. If I needed a suite on a PC I'd give it serious consideration.
   / Freeware Office suite software #12
I only very occasionally need a spreadsheet or word processor and am not into shelling out for each and every upgrade which has all sorts of new features which I don't need. It's Open Office for me.
   / Freeware Office suite software #13
The company I work for has an IT guy who loves to cheap out on us.
THIS ^ is almost certainly the reason for THIS v. Your IT guy is an idiot.
....have been using LibreOffice. While I haven't personally used it, the guys who do use it every day spend most of their time complaining about it not working right (won't open, freezes for no reason, etc.). I've watched it go bad on a couple of occasions
Libre Office is a derivative of Open Office. There really isn't much difference between them, and they are both reliable. If you are used to MS, you'll find Open/Libre Office to be different enough to be annoying, but you get used to it.
   / Freeware Office suite software #14
If google docs is working for you why change? The only issue would be that if you have no internet connection then you can't use it.
   / Freeware Office suite software #16
I'll not argue your assessment. I was just trying to be kind. :cool:
I would say a majority of said stupidity is driven by managements ideas to continue to reduce IT budgets in to dust and not give any choice. Ive seen this happen in numerous companies, big to small.
That said, Ive also seen some groups within IT make some pretty dumb choices on products and services when they've been given carte blanch spending.
Universal constant: you cant fix stupid.
2021 Freightliner Cascadia 116 T/A Day Cab Truck Tractor (A52377)
2021 Freightliner...
Heavy-Duty Ratchet Load Binders & Chains Set (A53117)
Heavy-Duty Ratchet...
2016 Ford F-450 Pickup Truck (A51692)
2016 Ford F-450...
2018 GENIE GTH-844 TELESCOPIC FORKLIFT (A52706)
2018 GENIE GTH-844...
22ft T/A Gooseneck Flatbed Equipment Trailer (A52377)
22ft T/A Gooseneck...
Michelin CARGOXBIB High Floatation Tires (SET OF 6) (A55301)
Michelin CARGOXBIB...
