Onan UF series 15.OUF-3S/104 generator
   / Onan UF series 15.OUF-3S/104 generator #1
RoyJackson
Rest in Peace
Bethel, Vermont
John Deere 4052R Cab,, Deere 855D UTV, Z920A Zero Turn Mower and assorted implements
My neighbor gave me a 15kW Onan generator. It's probably about 30 years old.
The problem is, the unit does not put out power. The Diodes had been replaced (but the neighbor thinks one may have been installed wrong...he's no electrician and neither am I.
Does anyone have any experience with this generator?
I'm not looking for repair techniques...more interested if it's worth putting a couple hundred dollars in to have it repaired.
BTW, this is a PTO powered generator.
   / Onan UF series 15.OUF-3S/104 generator #2
Generators aren't super complex machines. Check to see if the windings, gearbox & bearings are still good. If so, pretty much most other parts can be replaced reasonably. Look for a manual if you can. Old manuals told you how to diagnose & fix things unlike modern manuals.
Thanks for the info! I do have the manual and I even found a pdf version online.
But, I know nothing about electrical things...might be a good time to learn!
   / Onan UF series 15.OUF-3S/104 generator #5
Roy,
I would have it checked out by a shop and be sure to let them know about checking the diode installation. You should be able to get an estimate of repairs for less than a $100. Cummins would be the service outlet as far as I know. You could call your local dealer and ask a few questions.
Roy,
That's my plan, but I wanted to see if I could get any info on TBN first...mostly to see if it's worth putting any money into a repair.
   / Onan UF series 15.OUF-3S/104 generator #8
Does it have a capacitor? Is it excited?
2016 John Deere 410E 40 Ton Articulated Off-Road Dump Truck (A50322)
2016 John Deere...
Handlair 555 Grain Vac (A50514)
Handlair 555 Grain...
2012 Toro Greensmaster 1600 Walk Behind Mower (A48082)
2012 Toro...
2013 Chevrolet Caprice Sedan (A50324)
2013 Chevrolet...
Chevrolet C8500 Flat Bed with a Moffet Kit (A52128)
Chevrolet C8500...
2015 Timpte Hopper Bottom (A50514)
2015 Timpte Hopper...
