4020 where is hydraulic filter?
   / 4020 where is hydraulic filter? #1
Amherst Wisconsin
Ford 641 / 1963 Fordson Super Major
I have the filter. Not sure where this filter is at?
Can anyone give me a pic of its location?
Also was told there is a screen behind a plug ? Is there a pic where this is?
And lastly is there a fuel shutoff on the tank? To change filters?
Thanks Ty
   / 4020 where is hydraulic filter? #2
Maybe more info on tractor (tranny type - fuel type - serial number for break)
Hyd. filter schematic that may help. Can see key #23 for the screen.
You can find same at jdparts.com (free registration)
Fuel tank shutoff at bottom of tank.
   / 4020 where is hydraulic filter? #3
Thanks Ty
Filter cover is round with bolt in center located on LH(drivers) side. Screen plug is marked. What type trans does your tractor have(PS or Syncro) PS has 2 filters as per beenthere's schematic. Syncro-range has 1 filter. Yes there's a fuel shutoff in bottom of tank accessed in front of frt axle
Serial number is:
T213R 149610R
Thanks guys.
I am assuming the hydraulic filter base is in the pic with the screen you have noted?
Large round with the center nut?
And fluid must be drained to change filter?
any maintenance recommended on the air cleaner - oil bath on this tractor?
   / 4020 where is hydraulic filter? #7
Filter can be changed without draining hyd oil. Clean dirt out of air cleaner cup and refill with engine oil to full line in cup. Filter cover is round with bolt in center located on LH(drivers) side.
2009 Kenworth T800 Tri-Axle Day Cab Wet Kit Truck Tractor (A52377)
2009 Kenworth T800...
2024 JOHN DEERE 1025R LOT NUMBER 106 (A53084)
2024 JOHN DEERE...
2015 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A52377)
2015 Chevrolet...
2014 Chevrolet Tahoe SUV (A52377)
2014 Chevrolet...
2008 Komatsu WB146-5 (A47477)
2008 Komatsu...
